I am not able to ping device attached to the opposite interface of the router
Hi Guys
When I am trying to ping the address 10.30.0.84 of laptop attached to Gi0/1 from the laptop attached to interface to interface gi0/2 - not able
Able to ping 172.22.0.1 and 10.30.0.72 interfaces
What is the problem ? Configuration is attached
interface GigabitEthernet0/1
 ip address 10.30.0.72 255.255.255.224
 no ip route-cache
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
 no mop enabled
interface GigabitEthernet0/2
 ip address 172.22.0.1 255.255.255.0
 no ip route-cache
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
interface GigabitEthernet0/3
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
 media-type rj45
 no negotiation auto
ip default-gateway 10.30.0.65
ip route 0.0.0.0 0.0.0.0 10.30.0.65
ip route 172.22.0.0 255.255.255.0 GigabitEthernet0/1 10.30.0.65
ip http server
ip http authentication local
ip http secure-server
Mike
  • Silicon Valley Cisco User Group (SVCUG)
1 REPLY
VIP Purple
Hey
Hey
just couple of things command default-gateway is a layer 2 command only should be used on a switch with no routing in place , if the device has ip interfaces always use just the default route
have you enabled ip routing on the device locally and how do these routes know about each other whats doing the layer 3 routing , currently you just have a default route pointing to 10.30.0.65 , does this device have a route to both ips your trying to reach and does it sit inbetween your two devices trying to reach eachother ? why i say that is something has to control the routing, if your only using defaults and statics they need to be able to reach from each direction or else use some kind of IGP like eigrp where theres a routing table which contains all the routing information
9
