Bricked NSS4000
After unsuccessfull firmware upgrade my NSS4000 does not boot. It simply shows yellow power led, then blinking green power led.
I tested the "red blinking" recovery procedure by usb but it doesn't work.
What I can try before RMA it?
Re: Bricked NSS4000
Try removing ALL drives once the NSS is shutdown and then reboot (with drives ejected). If you end up in the same place; blinking Green Power light, perform a factory reset and try again. Factory reset will not erase disk data, just settings. If you are still not successful call Small Business Support Center.
Re: Bricked NSS4000
I did it. Same behaviour. So last resource is RMA.
Re: Bricked NSS4000
I have the exact same problem! Any solution for it? At the moment the thing is down :(
1241
