You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Can't mount to a subfolder of share folder
I have NSS326 and have couple of share folders created. The NFS is enabled for those share folders. I can mount to the share folder but I can't mount to its subfolder. For ex: share folder name "tools" and it has subfolder "windows". I can mount to "/tools" but can't mount to "/tools/windows" directly.I have some other NAS and they can do it by default configuration. So, I am wondering if I need to configure somethign to NSS326 to enable this.
TaiHung Lu
  • Small Business Network and Smart Storage
1 ACCEPTED SOLUTION
Re: Can't mount to a subfolder of share folder
Hi Tai,
  To mount to the sub-folder, you would need get the full path of where is that folder reside.
Example:
Network Share name: tools
Folder name: windows
mount NFS to network share would be /tools
mount NFS to a folder within the network share, you would do:  "/share/MD0_DATA/tools/windows" on any RAID array and for single disk. It would be "/share/HDA_DATA/tools/windows"
Hi Tai,
Example:
Thanks so much for your answer. Just a small change to your answer the folder in my case is /share/MD0_DATA/....
706
