Can't setup NSS322
Dears,
We've buy a Cisco Storage model NSS322 few weeks ago. Now I'm trying to install the equipment in my network, but I'm facing the following issues:
1 - I mounted the HDs on the equipment, and turned on. The NAS doesn't found the HDs (HD LEDs doesn't flash).
2 - eSATA LED indicator is always flashing orange (and I don't have a eSATA drive attached in it - even in any equipment on my office)
3 - LAN LED indicator is always flashing. Never goes solid
4 - Power is flashing green
5 - Setup Wizard shows the message: No unintialized servers found (doesn't found my NAS) all times I try to setup my NAS
6 - It doesn't reset - I put a paper clip on my storage, but it doesn't reset (and I'm not a beginner in this - I reseted and did setup in a lot of routers in my home and for my customers)
Could anybody here show me a light for my question? Do I need to send my NAS back to Amazon to exchange the equipment?
Thanks a lot, and Best Regards,
Leandro Fiore
Technical Support Engineer
MyABCM
leandro.fiore@myabcm.com
infra@myabcm.com
Everyone's tags (1)
Silver
Can't setup NSS322
Leandro,
First i would shut the unit down- pull drives out about an inch --> power unit back on.
Now access System Wizard - go through each step until you get to step 6 (RAID)
now push in each drive one at a time- Make sure you get a green light for each drive. Now under step 6 you should see the unit recognized the drive and should be able to select your RAID level and move on the next steps for competition.
Please call the Cisco Small Business Support Center and open a support case if you have futher trouble after this.
Jasbryan
Can't setup NSS322
Jasbryan,
Let me see if I understood your explain. Do I need to push the drivers with the storage turned on? As as hot swap HD?
Leandro.
Silver
Can't setup NSS322
Leandro,
hope you were able to get your NSS up and running. Did you call the support center for assistance? Sorry for the late response but if you need any assistance and don't get a response back promptly please call our support center for assistance @ 1-866-606-1866
Jasbryan
691
