How to open a port on firewall
I have a RV110W firewall installed. Now behind this firewall there is a server running. I need to access this server from outside of the store through a specific TCP port.
Physical connection from outside to the server is like this.
Outside -> Router -> Firewall -> Server
Router IP: 192.168.1.1
Firewall WAN IP: 192.168.1.5
Firewall LAN IP: 192.168.2.1
Firewall Gateway IP: 192.1681.1
Server IP: 192.168.2.10
The firewall is in gateway mode.
Now I forwarded a TCP port on router to firewall (192.168.1.5) and on the firewall i forwarded the same port to server (192.168.2.10).
On the server system, i opened the port on windows firewall for inbound.
This there anything I am missing?
Everyone's tags (1)
1 REPLY
Hello
Hello
your steps seems to be fine at first look, but somewhere in that chain there is probably something broken.
  • what kind of service is on that server port?
  • are you able to open connection from outside with telnet to Router WAN IP and port? example test from outside/internet:
telnet X.X.X.X YYYY
where X.X.X.X is WAN IP of Router and YYYY is port number.
You can confirm that port forwarding is working on both devices:
  • you can try to connect with computer between Router and Firewall and try that port on firewall.
  • if previous test works, then for testing purposes move server to subnet between Router and Firewall and perform connectivity test from internet.
220
