NSS 324 lost AD information and will not pull AD data from Windows 2003 Domain
Our NSS324 was/is connected to a W2K3 domain, after a reboot, all AD information was lost, the sysetm is still part of the domain (and has been pulled out of it and rejoined to it) but no AD information will appear when you attempt to set permissions from within the Admin Webpage.
  • Small Business Network and Smart Storage
ikt
Cisco has transferred all further development of software to the Qnap. Upgrade to the latest Qnap firmware.
http://www.qnap.com/cisco.asp
http://www.siliconloons.com/?p=101
This should solve your problems. I had the same problems you had.
Marius
Nope, that didn't work.  In fact when I attempt to load the Qnap firmware indicated the Cisco NAS tells me the upload failed and to be sure and check the firware date.  I'm currently running Cisco's v1.5.0.3 NSS firware...
ikt
Did you try downloading the firmware for Model Name: TS-459 Pro+ Turbo NAS ? Unziping the file and trying upgrading your NSS with the .img file?
Nope, downloading that one right now...
Nope, that didn't work either.  I'm now running under the Qnap Firmware with the Qnap color scheme and the menu's are changed slightly, but the system still will not pull in AD information, it cycles showing that it is loading information, but then shows a blank section instead of any of the domain user information, same for domain groups.  It is a part of the domain as I purposely changed the description under the Network Services setting and it indicated that it joined the domain successfully, but it still will not pull in any domain user or group info...
ikt
I had to wait 30 - 60 sec in the first time and then the Domain Users and Domain User Groups appeared under: Access Right Management - Share Folders - Folder Premissions...
Silver
Daniel,
What are the logs showing on NSS324?
Do you have your Time sync with your domain controller, DNS configured and AD information set. If time is off more than 3-5 minutes can cause domain sync problems. I set my time manually and pointed it back to my DC.
Jasbryan
1166
