nss 326:trunking mode ieee 802.3ad
hi all
i have configured cisco nss 326 for ieee 802.3ad trunking but in administration>network interfaces shown as 1000Mbps.
I have made the correct lacp configuration at my 6509 switch and the port channel shows as follows:
6509#sh etherchannel 14 summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
Number of channel-groups in use: 8
Number of aggregators:           9
Group  Port-channel  Protocol    Ports
14     Po14(SU)        LACP      Gi1/24(P)  Gi1/25(P)
MLR_6509#sh interface ethw
MLR_6509#sh interface etherchannel 14
% Invalid input detected at '^' marker.
MLR_6509#sh interface etherchannel po
MLR_6509#sh interface port
MLR_6509#sh interface port-channel 14
Port-channel14 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0007.0e14.8110 (bia 0007.0e14.8110)
  Description: ***CISCO-NSS***
  MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 49/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s
  input flow-control is off, output flow-control is on
  Members in this channel: Gi1/24 Gi1/25
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2519000 bits/sec, 4657 packets/sec
  5 minute output rate 384959000 bits/sec, 31714 packets/sec
     55407239 packets input, 5193296617 bytes, 0 no buffer
     Received 19175 broadcasts (12671 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     364136328 packets output, 550574431379 bytes, 0 underruns
     0 output errors, 0 collisions, 13 interface resets
any ideas?
1 REPLY
Gold
Hi Vasilios,
The NSS326 will always show 1000Mbps, even when trunking is enabled and functioning.
711
