Password after factory reset ?
i don´t know what happend.. but i think its really strange. Ok first i upload a new configuration on my NSS4000, after this the device restarts. -So long-
After the reboot procedure the device is available over http:\\ but.. my admin password doesn´t work...
- ok after the first shock i use the factory reset... but oh no.. the standard admin password doesn´t work either ?!?!
Please can anyone help me ;)  its really annoying...
i´ve found that there´re two ports open 888 and 8888... but i don´t have the right password for this too....
Everyone's tags (1)
1 REPLY
Re: Password after factory reset ?
One thing to always remember is that when upgrading firmware it needs to be applied twice. This will ensure that all settings migrate and are applied properly. Perform a full reset of the unit by following these steps:
Step 1:
Shut down and power off the system.
Step 2:
Press and hold the Reset button on the front panel of the chassis then apply power to the system.
Step 3:
Wait until you see the Power LED on the front panel to flash yellow rapidly then release the Reset button.
Note: The following will be reset to their default settings:
  • Link Addressing: DHCP
  • Link Bonding Mode: Active Backup
  • NSS Hostname: nas For example, "nas0123456789ab"
  • Administrator Password: admin
  • Network Filters: cleared
  • Network Default Policy: Accept All
  • MTU Size: 1500
Once this completes, go ahead and re-install the firmware and save your configuration. Let us know if you are still not able
to access the NAS.
2832
