Community Member
3845 Router redundant power supply question
Is it possible to swap out a bad redundant power supply on a 3845 router without powering down the router?
1 ACCEPTED SOLUTION
Re: 3845 Router redundant power supply question
The FAQ at this URL indicates that they ARE in fact hot-swappable.  Please review it here, under "System Power (AC/DC)".
Community Member
You were indeed correct.
The power supply has been successfully replaced without powering down the router.
5323
