Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Basic Port Foward 877-M
I have been trying to forward port 8080 from our public IP address to our local 192.168.1.20 server using the GUI. No Luck.
I have restored to factory defaults and just tried to forward this port. No Luck.
I have tried to use the CLI. No Luck, but I was a little out of my depth.
I have attached a file with some basic settings, let me know if you need any more.
Everyone's tags (4)
Re: Basic Port Foward 877-M
Hi Rupert,
I'd suggest that you use the SDM (Security Device Manager) application to configure the 877.
If you want to use CLI, first ensure that NAT has been configured for outbout use, then add a command like the following (assuming that you are using TCP):
ip nat inside source static tcp 192.168.1.20 8080 interface FastEthernet4 8080
Andy
Check out the below link for more information hope to help, As suggested nat will be used to forward the traffic in transalated ip and specific port.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml#topic8
Hope to help !!
Ganesh.H
I am not having too much luck, is there anything I can "show" so that I can see the problem. I have run the given commands and followed the guide.
How do I configure the outside NAT? Dont forget the 877 is a modem router.
Dialer 0 is where the Internet comes in. The web server on port 8080 is physically connected to "fe2" at the back of the device.
Interfaces are:
FastEthernet0 is up
FastEthernet1 is up
FastEthernet2 is up
FastEthernet3 is up
ATM0 is up
ATM0.1 is up
Vlan1 is up
Dialer0 is up
Bound to:
Virtual-Access1 is up
NVI0 is up
782
