Best Firewall Settings on RV082 ?
Are these the best settings for firewall to achieve VPN pass-through?
ENABLE:  Firewall; SPI, DoS attacks; Remote Mgmt; Multicast passthrough
DISABLE: Block WAN; HTTPS
I need remote management but probably not https for management.  Does multicast passthrough reduce Internet speed?
For reliable VPN, customer is asking to open UDP ports 500 & 4500.  By default, aren't all ports open on router.  If not, how do you open a port for all users?
Silver
Re: Best Firewall Settings on RV082 ?
Jpoldoian, by default the firewall will block all ports coming from outside the wan to the lan.  For vpn passthrough, by default it is enabled.  The port forwarding 500 and 4500 can be forwarded directly to a device that your using vpn to connect to.
Silver
Multicast passthrough, does not reduce internet speed on the router, it just allows multicast addresses to enter the routers wan.
615
