04-20-2012 08:20 AM
Dear gurus
We would much appreciate your input for a headachless join of two networks.
Due to bandwith requirements, we need to join a network with an RV016 to a network with an RV082 via a point to point air bridge. (VPN over adls was not cutting it) fortunatelly there is line of sight.
We would appreciate if you could advice the propper, procedure.
The info
LocationA LocationB
RV016 RV082
WAN1 ADSL modem WAN1 ADSL Modem
WAN2 DedicatedIP modem WAN2 Free
WAN3..7 free
192.168.0.1 192.168.1.1
255.255.255.0 255.255.255.0
DHCP DHCP
Servers on LAN Servers on LAN
We need LAN-B endpoints to be able to reach servers on location A and viceversa
We pre configured two point to point radios for the tower people to install. (we could change this configs)
Topology (crude sketch)
http://screencast.com/t/JoLKCvhoFO
Our questions: best port to plug the radios into the RVs WAN ports? switch ports? What rules or static routes need to be created?
We do not wish to change the IP clases/subnets if possible. All suggestions, pointers and ideas are welcomed.
looking forward to this.
04-21-2012 11:38 AM
Any ideas? bump
04-27-2012 05:14 PM
Hello again
We got the point to point delivered.
The radio on location A is plugged to a switch port on the RV016
The radio on location B is plugged on WAN2 on the RV082, which gets an IP via DHCP of LAN_A
The router on location B, 192.168.1.1 can ping 192.168.0.1 and devices in 192.168.0.XX, but devices on Location B cannot ping anything on location A
The router on location A, 192.168.0.1 cannot ping the router on location B, 192.168.0.1 nor anything on that network.
We need devices on location B 192.168.1.1~254 to be able to reach a server on location A under 192.168.0.1~254
Please advice, thanks
