New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
Can not get RV042 vpn connection to work
I am trying to get my RV042 back to our office cisco 2911. I just can not get it to connect. I have tried aggressive mode on and off and made sure the times sync. I still can not get it to work. Here is the log from the RV042
Sep 2 09:09:30 2013           VPN Log           (g2gips0) #2793: initiating Quick Mode PSK+ENCRYPT+TUNNEL {using isakmp#2791}
Sep 2 09:09:30 2013           VPN Log           (g2gips0) #2793: [Tunnel Negotiation Info] >>> Initiator send Quick Mode 1st packet
Sep 2 09:09:30 2013           VPN Log           (g2gips0) #2791: ignoring informational payload, type NO_PROPOSAL_CHOSEN
Sep 2 09:09:54 2013           VPN Log           (g2gips0) #2790: max number of retransmissions (2) reached STATE_QUICK_I1. No acceptable response to our first Quick Mode message: perhaps peer likes no proposal
Sep 2 09:09:54 2013           VPN Log           (g2gips0) #2790: starting keying attempt 2 of an unlimited number
Sep 2 09:09:55 2013           VPN Log           (g2gips0) #2794: initiating Quick Mode PSK+ENCRYPT+TUNNEL to replace #2790 {using isakmp#2791}
Sep 2 09:09:55 2013           VPN Log           (g2gips0) #2794: [Tunnel Negotiation Info] >>> Initiator send Quick Mode 1st packet
Sep 2 09:09:55 2013           VPN Log           (g2gips0) #2791: ignoring informational payload, type NO_PROPOSAL_CHOSEN
Sep 2 09:10:20 2013           VPN Log           (g2gips0) #2792: max number of retransmissions (2) reached STATE_QUICK_I1. No acceptable response to our first Quick Mode message: perhaps peer likes no proposal
Sep 2 09:10:20 2013           VPN Log           (g2gips0) #2792: starting keying attempt 2 of an unlimited number
Sep 2 09:10:20 2013           VPN Log           (g2gips0) #2795: initiating Quick Mode PSK+ENCRYPT+TUNNEL to replace #2792 {using isakmp#2791}
Sep 2 09:10:20 2013           VPN Log           (g2gips0) #2795: [Tunnel Negotiation Info] >>> Initiator send Quick Mode 1st packet
Sep 2 09:10:20 2013           VPN Log           (g2gips0) #2791: ignoring informational payload, type NO_PROPOSAL_CHOSEN
Sep 2 09:10:40 2013           VPN Log           (g2gips0) #2793: max number of retransmissions (2) reached STATE_QUICK_I1. No acceptable response to our first Quick Mode message: perhaps peer likes no proposal
Sep 2 09:10:40 2013           VPN Log           (g2gips0) #2793: starting keying attempt 2 of an unlimited number
Sep 2 09:10:41 2013           VPN Log           (g2gips0) #2796: initiating Quick Mode PSK+ENCRYPT+TUNNEL to replace #2793 {using isakmp#2791}
Sep 2 09:10:41 2013           VPN Log           (g2gips0) #2796: [Tunnel Negotiation Info] >>> Initiator send Quick Mode 1st packet
Sep 2 09:10:41 2013           VPN Log           (g2gips0) #2791: ignoring informational payload, type NO_PROPOSAL_CHOSEN
Sep 2 09:11:04 2013           VPN Log           (g2gips0) #2794: max number of retransmissions (2) reached STATE_QUICK_I1. No acceptable response to our first Quick Mode message: perhaps peer likes no proposal
Sep 2 09:11:04 2013           VPN Log           (g2gips0) #2794: starting keying attempt 3 of an unlimited number
Sep 2 09:11:04 2013           VPN Log           (g2gips0) #2794: [Tunnel Negotiation Info] ipsecdoi_initiate: (g2gips0) has retry 3 times [policy:25; serial no:aea], so reset this connection!
Sep 2 09:11:04 2013           VPN Log           (g2gips0) #2797: initiating Main Mode
Sep 2 09:11:04 2013           VPN Log           (g2gips0) #2797: [Tunnel Negotiation Info] >>> Initiator Send Main Mode 1st packet
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: [Tunnel Negotiation Info] <<< Initiator Received Main Mode 2nd packet
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: [Tunnel Negotiation Info] >>> Initiator send Main Mode 3rd packet
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: ignoring Vendor ID payload [Cisco-Unity]
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: received Vendor ID payload [Dead Peer Detection]
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: ignoring Vendor ID payload [efb03935c7a220d40da3e4f64e3a328b]
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: ignoring Vendor ID payload [XAUTH]
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: [Tunnel Negotiation Info] <<< Initiator Received Main Mode 4th packet
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: [Tunnel Negotiation Info] >>> Initiator Send Main Mode 5th packet
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: [Tunnel Negotiation Info] >>> Initiator Receive Main Mode 6th packet
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: Peer ID is ID_IPV4_ADDR: 'xx.xxx.xxx.xxx'
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: [Tunnel Negotiation Info] Main Mode Phase 1 SA Established
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: ISAKMP SA established
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2798: initiating Quick Mode PSK+ENCRYPT+TUNNEL {using isakmp#2797}
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2798: [Tunnel Negotiation Info] >>> Initiator send Quick Mode 1st packet
Sep 2 09:11:05 2013           VPN Log           (g2gips0) #2797: ignoring informational payload, type NO_PROPOSAL_CHOSEN
Sep 2 09:11:05 2013           VPN Log           packet from xx.xx.xxx.xxx:500: Informational Exchange is for an unknown (expired?) SA
1 REPLY
Community Member
1163
