Cisco 892 NAT or Routing assistance for VoIP
I have some experience with Cisco switches but not with Routers. I'm trying to connect a small intrenal network to FastEthernet8 port and the WAN connected to Gigabit 0. I was able to configure DHCP for the internal network but have been several days trying to figure out how to get it to route all traffic through the WAN interface. I'm attaching below my current configuration. Any help would be greatly appeciated.
Current configuration : 1542 bytes
! Last configuration change at 00:15:51 UTC Sun Aug 24 2014
version 15.0
hostname sgivoip
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip dhcp excluded-address 192.168.11.1 192.168.11.30
ip dhcp pool insideDHCP
network 192.168.11.0 255.255.255.0
default-router 192.168.54.202
dns-server 167.206.112.138 167.206.7.4
ip cef
no ipv6 cef
license udi pid CISCO892-K9 sn FGL1710231R
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
isdn point-to-point-setup
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
ip address 192.168.11.1 255.255.255.0
duplex full
speed auto
interface GigabitEthernet0
ip address dhcp
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password ***
login
scheduler max-task-time 5000
end
Everyone's tags (1)
1 ACCEPTED SOLUTION
I'm trying to understand what
I'm trying to understand what this default-router 192.168.54.202 entry is doing in your DHCP pool? This would typically be 192.168.11.1 or whatever you want your router to be. You will need to add the following commands:
interface F8
ip nat inside
interface G0
ip nat outside
ip access-list standard NAT
 permit 192.168.11.0 0.0.0.255
ip nat inside source list NAT interface G0 overload
That should do it. If you have further issues I would recommend powering off your cable modem for a couple minutes then powering back on and then powering your router on. To see if you have received an IP address you could run show ip interface brief and next to G0 you should see an outside IP address.
interface F8
ip nat inside
interface G0
ip nat outside
Thank you so much Michael:
Thank you so much Michael:  this is great!!!  these commands took care of the issue. Router is now providing NAT! I also changed the default-router to 192.168.11.1.  It worked well!
Regards,  Jorge
153
