Community Member
Cisco Linksys RVS4000 - Unexpected packet
Hello.
I have problem with Cisco Linksys RVS4000 when I like to connect throw PPPoE protocol on internet.
Everything are set correct. Router works one year without any problem. Another linksys router but not same model works without any problem.
This problem happen 3x time (6 month). 2 times ISP successful resolve the problem when manual insert setting on their cisco. Last one They can't resolve it, setings on theri cisco already set?!
I try with my old firmware and with new one v1.3.3.5. Both from offical site cisco.com.
Try already try set MTU, trunk etc... without success.
Can you help me?
Thank you.
Log:
Feb 1 20:58:31 - Plugin pppoe loaded.
Feb 1 20:58:31 - PPPoE Plugin Initialized
Feb 1 20:58:31 - Plugin pppoe called.
Feb 1 20:58:31 - pppd 2.4.1 started by root, uid 0
Feb 1 20:58:31 - Sending PADI
Feb 1 20:58:45 - HOST_UNIQ successful match
Feb 1 20:58:45 - Unexpected packet: Ether addr: 00:90:1a:42:13:92 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0036 (PADO) PPPoE tag: type=0102 length=0012 (AC Name) data (UTF-8): E320-BRAS-KP-KOPER PPPoE tag: type=0103 length=0004 (Host
Feb 1 20:58:45 - Unexpected packet: Ether addr: 00:90:1a:42:72:38 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0036 (PADO) PPPoE tag: type=0102 length=0012 (AC Name) data (UTF-8): E320-BRAS-KP-KOPER PPPoE tag: type=0103 length=0004 (Host
Feb 1 20:58:45 - Unexpected packet: Ether addr: 00:90:1a:42:69:bb (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0038 (PADO) PPPoE tag: type=0102 length=0014 (AC Name) data (UTF-8): E320-BRAS-LJ-DRAVLJE PPPoE tag: type=0103 length=0004 (Hos
Feb 1 20:58:45 - Unexpected packet: Ether addr: 00:90:1a:42:71:c9 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x003b (PADO) PPPoE tag: type=0102 length=0017 (AC Name) data (UTF-8): E320-BRAS-LJ-CIGALETOVA PPPoE tag: type=0103 length=0004 (
Feb 1 20:58:45 - Unexpected packet: Ether addr: 00:90:1a:42:71:31 (PPPOE Discovery) PPPoE hdr: ver=0x1 type=0x1 code=0x07 sid=0x0000 length=0x0038 (PADO) PPPoE tag: type=0102 length=0014 (AC Name) data (UTF-8): E320-BRAS-LJ-DRAVLJE PPPoE tag: type=0103 length=0004 (Hos
Feb 1 20:58:45 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x427d8
Feb 1 20:58:45 - Couldn't get channel number: Transport endpoint is not connected
Feb 1 20:58:45 - Doing disconnect
Feb 1 20:58:45 - Exit.
717
