Cisco RV042 outlook over http issue
Hello
I have recently bought a CISCO RV042 10/100 4-port VPN Router. I configured it and installed it to replace the old LinkSYS WAG320N Router.
My issue is our remote users that use Outlook over HTTP can't send large emails or emails with attachments while the Cisco RV042 is plugged in, but they can send small emails. With the Linksys WAG320N it works fine.
My set up is:
Only use one WAN1 interface on connection type PPPoE with Auto MTU
Port Range Forwarding for HTTP, HTTPS and SMTP are all pointing to the exchange server
UPnP Function: No
DHCP: Off
Under Firewall settings, Remote Management disabled, HTTPS Disabled
I have spent many of hours changing settings to try to get it to work. I have also tried resetting to factory defaults and updating the firmware to v4.2.3.03
I have run SMTP tests and OWA works fine.
Does anyone have any suggestions on my problem please?
Rory
71
