06-05-2012 06:35 AM
Is there a way to configure the router through CLI (command line interface)
In other Cisco devices we always were able to simply insert a configuration throught the CLI.
Now it seems it can only be done with the Webbrowser.
Tom
Solved! Go to Solution.
06-05-2012 10:09 AM
Tom,
No. The RV110W can only be configured via a web browser. There is no command line interface support for this router.
Chris
06-06-2012 03:11 AM
The RV220W and RV120W has the feature on the WAN. I can only guess in a possible future firmware update that this maybe an option for you.
Regards Simon
http://www.linksysinfo.org
06-05-2012 10:09 AM
Tom,
Chris
06-06-2012 12:14 AM
chchapma,
Thanks for your reply. In our company we do alot with fiber connections. Do you know how I can set the WAN port setting to 100MB Full-Duplex? (auto-negotiate needs to be off)
This is needed for the fiber connection, but it seems that I can only change port settings for the LAN ports.
Tom
06-06-2012 03:11 AM
Regards Simon
06-06-2012 04:01 AM
Thank you both
06-06-2012 09:04 AM
Networking > LAN > Port Management.
Sorry, this isn't for the WAN port...
06-07-2012 02:33 AM
Yes i know, it's strange they have it on LAN but not on WAN.
On the WAN port is where I need it to be. But thank you anyway ;-)
10-25-2012 04:16 PM
I too would like to set the WAN side, I want 10M Full because our gateway device wants that setting. I put a laptop on the gateway device, setting the laptop to auto negotiate I get way worse throughput than when I set the laptop to force a 10M Full Duplex connection.
So, I am posting hoping to help inspire CISCO to add the setting to the firewall software...
And an idea... I'm hoping that if I can find an ancient 10Meg only switch and put that in between the RV110W and my gateway device it may fix the problem. ( I am getting 3MB down and 4MB up on the inside on a symmetrical 4MB limited connection whereas the laptop directly in gets darn near to 4MB up and down ).
