Cisco SRP 521w Resetting - Port State Wrong?
I have a Cisco SRP 521w. It has been upgraded to the latest firmware. Its a very simple setup with two VLANs and no VoIP. I have disabled the VoIP line 1 and 2 as discussed elsewhere on this forum. However, even after doing that, the router seems to reset itself every week or so. The intervals are random. Sometimes it goes for 10-15 days without resetting, sometimes it only goes 1-2. I'm at a loss as to why this is. Here is what the log says when it resets:
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: check_interface_usage: brdige(br1) port state wrong?
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^Ibr1
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I bridge id^I^I8000.2037063a3481
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I designated root^I8000.2037063a3481
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I root port^I^I   0^I^I^Ipath cost^I^I   0
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I max age^I^I   2.00^I^I^Ibridge max age^I^I  20.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I hello time^I^I   2.00^I^I^Ibridge hello time^I  20.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I forward delay^I^I  20.00^I^I^Ibridge forward delay^I   2.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I ageing time^I^I 300.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I hello timer^I^I   1.32^I^I^Itcn timer^I^I   0.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I topology change timer^I   0.00^I^I^Igc timer^I^I 288.92
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I flags^I^I^I
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^Ieth1.1 (1)
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I port id^I^I8001^I^I^Istate^I^I     forwarding
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I designated root^I8000.2037063a3481^Ipath cost^I^I 100
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I designated bridge^I8000.2037063a3481^Imessage age timer^I   0.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I designated port^I8001^I^I^Iforward delay timer^I   0.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I designated cost^I   0^I^I^Ihold timer^I^I   0.32
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^Iath0 (2)
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I port id^I^I8002^I^I^Istate^I^I       learning
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I designated port^I8002^I^I^Iforward delay timer^I   1.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: check_interface_usage: brdige(br2) port state wrong?
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^Ibr2
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I hello timer^I^I   1.26^I^I^Itcn timer^I^I   0.00
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I topology change timer^I   0.00^I^I^Igc timer^I^I 291.38
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^Ieth1.2 (1)
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I designated cost^I   0^I^I^Ihold timer^I^I   0.26
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^Iath1 (2)
Feb  1 13:20:12 SRP521W daemon.emerg rc[1049]: ^I designated port^I8002^I^I^Iforward delay timer^I   1.17
Does anyone have any info as to what this means and how to fix it?
Thank you!
Everyone's tags (4)
868
