New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
Clearing Startup-Config/NVRAM on 1841 after lightning strike
We have two 1841 that only boot to Rommon mode. One says the IOS is corrupt every time, even when I take the Flash Memory out and do a Verification check on a working router and the IOS passes. The other one just boots directly to ROMMON mode even when I use the same verified IOS on flash memory. We know both routers are done for and are needing to clear the NVRAM anyway possible before getting rid of them. Is there anyway manualy or through ROMMON mode we can clear the NVRAM/Startup-Config before we dispose of the routers.
David Johnson
1 REPLY
Hall of Fame Super Blue
If you give the routers back
If you give the routers back to Cisco, they'll be taken care of.
84
