Connect ShrewSoft vpn client to Cisco RV220W
Hi ,
I can't get QuickVPN work with Cisco RV220W router, so configured ShrewSoft vpn client
to connect to router with xauth advanced vpn configuration. It established tunnel , but no any ping is working from client to office computers or even
to router IP (gateway) . What is wrong with my setup ?
"Basic VPN Setup" doesn't allow me to save new "VPN client" : it throws strange error "IPsec VPN configuration
has failed as the remote end point is already in use" .
I attached example of xauth advanced vpn configuration
Alex
  • Small Business Routers
Hi Alexey, thank you for using our forum, my name is Luis I am part of the Small business Support community.
If you want I could share to you an article created especially for QuickVPN, you could follow those instructions in order to configure your Remote VPN, Remote VPN tunnel.
Also I will share to you this other article with some reason that you couldn't be able to connect to a remote VPN.
REASONS YOU CANNOT CONNECT WITH QUICKVPN
I hope you find this answer useful
Greetings,
Luis Arias.
Cisco Network Support Engineer.
Hi Luis ,
I did many checks on different Windows XP/7 through different ISP's of QuickVPN , according a lot of Cisco and community documents with same negative result , that it can't ping remote gateway .
QuickVPN requires so many things to configure and check , that turns it to be impossible for use in company.
I wanted to configure client-to-gateway VPN with IPsec xauth , that is supported by Cisco Small Business routers.
Finally i configured client-to-gateway IPsec remote connection using both ShrewSoft and TheGreenBow 3d party VPN application. It was just matter to turn local host (VPN client) adapter mode to virtual with static IP address in subnet , different from remote (gateway) subnet.
Alexey
1650
