difference between SRP520W and SRP520-U
Hi all,
i have tried to see the difference between the routers series:
srp 520w series
and
srp 520-u series
but with no success.
is it possible to know the differences between this two series?
thank you
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Paolo,
Those are the hardware differences (that at the colour of the bezel - the SRP520-U is black).
The big difference that comes with the hardware upgrade is the support for firmware.
The original SRP520 models run (and will only run) version 1.1.x releases.
The new SRP520-U models run the 1.2.x code train (only) - this is the same code base as the SRP540 models.
Hope that helps,
Andy
finally i have found some difference:
https://supportforums.cisco.com/message/3531438
Hi Paolo,
Hope that helps,
Andy
Hi Andrew,
thanks for your reply.
I need some features (like ACL for example, "advanced" NAT etc etc) which are supported by the 1.2.x firmware and not by the 1.1.x that's why I was asking for differences between the two models.
now everything it's more clear to me.
unfortunatelly i am still not finding the cisco 520U series into the official italian distributor market.
thanks again
1263
