DNS Question on RV320
I want to use the local DNS on RV320 for the internal network.  I would like to know the difference between the "DNS Proxy" and "Use this DNS" based on how it queries the local db.  Does the proxy just look at the local and if it doesn't find an entry, it then goes to the DNS listed in the LAN setup?  If I "Use this server" and enter the address of the VLAN,  what does it do when it can't find the entry locally?  Does the local DNS cache data from other DNS servers?
1 REPLY
the dns proxy will cache requests for names and respond locally if they are cached.
if it doesn't find an entry it goes to the dns configured on the WAN port.
If you are using a dns (say MS SBServer) on the LAN side, you would point your clients to the local SBS server, then point the SBS resolver in the dns server to the router.
Dan
From the admin guide p51
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/administration/guide/en/rv32x_ag_en.pdf
Domain Name Service (DNS) matches a domain name to its routable IP address.
You can set up a DNS Local Database that enables the device to act as a local DNS
server for commonly used domain names. Using a local database might be faster
than using an external DNS server. If a requested domain name is not found in the
local database, the request is forwarded to the DNS server that is specified on the
Setup Network
> WAN Setting page.
If you enable this feature, you also must configure the client devices to use the
device as the DNS server. By default, Windows computers are set to obtain a DNS
server address automatically from the default gateway.
356
