06-08-2010 03:25 PM
Hi - I have an RV082 (running 2.0.0.19-tm) set up as the gateway to the Internet on my home LAN, and connect to it through several switches / hubs around my house. Randomly, and from various connections around the house (which are all plugged in to different ports of the RV082), a Web request will fail to load, giving a "Server not found" error in the browser.
When I look at the log in the RV082, it says, "Connection Refused: Policy Violation".
It seems to be just blocking the DNS requests - everything else appears to go through normally. For example, I get the message "Looking up domainname.com" in the bottom corner of the browser and the request fails, displaying the Mozilla "Server not found" error page. When I click the "Try Again" button the page, it goes through just fine and everything works.
I don't have any services running behind the firewall, and do not use the VPN settings. Here are my current firewall settings:
Firewall : | Enable | Disable | ||
SPI (Stateful Packet Inspection) : | Enable | Disable | ||
DoS (Denial of Service) : | Enable | Disable | ||
Block WAN Request : | Enable | Disable | ||
Remote Management : | Enable | Disable | Port: | |
HTTPS : | Enable | Disable | ||
Multicast Pass Through : | Enable | Disable |
Things I've tried:
Any ideas?
- Rob
05-07-2013 02:39 AM
Has there been a solution for this problem meanwhile?
I also run a RV082 with 2.0.2.01 and the same Problem.
Martin
05-07-2013 06:45 AM
Prior to 2.0.2.01 it worked. Now it's BROKEN !! And this is how:
The RV082 local DNS "database" / list, if active, was ALWAYS searched first before the lookup request was sent to the DNS server for WAN1 / WAN2, who's IP addresses I supplied on the RV082 Setup panel.
The BUG is readily circumventable. To make it work as before you now must specify *maually* a static *DDNS* IPaddress for all (dynamic ip) guest adapters, e.g. 192.168.2.1, the ipaddr of the RV082. If you don't then the RV082 will supply the ipaddress of the external DNS service provider (WAN1/WAN2 Setup) AND thus the RV082 local DNS is bypassed, ignored.
I really wish that CISCO would fix this !!
