Does Mac OSX VPN client work with RV042G routers?
I purchased a RV042G but the documentation doesn't make any reference that this router supports Mac OSX 10.8 or any other OSX version.
I appreciate any reply.
1 ACCEPTED SOLUTION
Green
Does Mac OSX VPN client works with RV042G routers?
Hi Marcos, yes, for PPTP. The IPsec built in does not work by default as it is the "same" as the Cisco VPN 5.x.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Green
-Tom
Tom,
Is there a third party VPN client for MAC that can be used for this router? Like Open VPN?
Marcos
Green
Ipsecuritas
-Tom
Thank you. I will check it out!
1822
