dual isp load balancing while NAT is in operation
Please send me a sample configuration for dual isp load balancing while NAT is in operation.
1 ACCEPTED SOLUTION
ollyahmed, If you are looking
ollyahmed
If you are looking specially for a router,then following configuration would be good.
there is a quick need to modify the configuration according to the type of configuration you are running , i mean (QOS policies, route directions and Tracking(ip sla).
version 15.2
ip cef
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
class-map match-all skype
match protocol skype
policy-map skype-policy
class skype
  set dscp ef
interface GigabitEthernet0/0
description LAN ip address 10.0.0.1 255.255.254.0 ip nat inside ip virtual-reassembly in duplex auto speed auto
interface GigabitEthernet0/1
description TASK
ip address 213.192.65.106 255.255.255.252 ip access-group 101 in ip nat outside ip virtual-reassembly in duplex auto speed auto crypto map GLIWICE-MAP service-policy input skype-policy service-policy output skype-policy
interface GigabitEthernet0/2
description "Wit-NET" mac-address 0030.4f61.5521 ip address 193.107.215.133 255.255.255.224 ip access-group 101 in ip nat outside ip virtual-reassembly in duplex auto speed auto
ip default-gateway 213.192.65.105 ip forward-protocol nd
ip nat inside source route-map nat_isp1 interface GigabitEthernet0/1 overload ip nat inside source route-map nat_isp2 interface GigabitEthernet0/2 overload
ip nat inside source static tcp 10.0.0.24 777 193.107.215.133 777 extendable ip nat inside source static tcp 10.0.0.2 1723 193.107.215.133 1723 extendable ip nat inside source static tcp 10.0.0.24 777 213.192.36.106 777 extendable
!---more static routes has been omitted---
ip default-network 213.192.65.105 ip route 0.0.0.0 0.0.0.0 213.192.65.105 track 1
ip route 0.0.0.0 0.0.0.0 193.107.215.129 track 2
ip sla 1
icmp-echo 213.192.65.105 source-interface GigabitEthernet0/1
threshold 2 timeout 1000 frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2 icmp-echo 193.107.215.129 source-interface GigabitEthernet0/2 threshold 2 timeout 1000 frequency 5
ip sla schedule 2 life forever start-time now
access-list 110 deny   ip 10.0.0.0 0.0.1.255 10.0.100.0 0.0.0.255
access-list 110 permit ip 10.0.0.0 0.0.1.255 any access-list 190 permit ip 10.0.0.0 0.0.1.255 10.0.100.0 0.0.0.255
route-map TASK permit 10
match ip address 110
match interface GigabitEthernet0/1 !
route-map track_isp permit 10 match ip address 101 match interface GigabitEthernet0/1 set ip next-hop 213.192.65.105
route-map track_isp permit 20 match ip address 102 match interface GigabitEthernet0/2 set ip next-hop 193.107.215.129 ! route-map nat_isp2 permit 10 match ip address 110 match interface GigabitEthernet0/2 ! route-map nat_isp1 permit 10 match ip address 110 match interface GigabitEthernet0/1 ! - See more at: https://supportforums.cisco.com/discussion/11710646/dual-isp-connection-and-load-balancing#sthash.m0FSJNmn.dpuf
Hi Ollyahmed, This will be
Hi Ollyahmed,
This will be different depending on what device you are talking about? I would assume you are talking about a router as that is where you would set up the dual ISP for load balancing. If this is on a Cisco Small Business router then it will work by default like the RV0xx series and the RV32x series.
Silver
If you are using ASA5500
If you are using ASA5500 series firewall, try to do the following....
ciscoasa#
ciscoasa# sh run
: Saved
ASA Version 8.0(4)
hostname ciscoasa
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
 nameif outside
 security-level 0
 ip address (publicIP-1)
 nameif backup
 security-level 0
 ip address (publicIP-2)
 nameif inside
 security-level 100
 ip address (privetIP-LAN)
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 nameif management
 security-level 100
 ip address (mangment-IP)
 management-only
ftp mode passive
object-group network inside-net
 network-object 0.0.0.0 0.0.0.0
access-list 101 extended permit tcp any any eq www
pager lines 24
logging asdm informational
mtu outside 1500
mtu backup 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-613.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (backup) 1 interface
nat (inside) 1 (LAN-Network-IP)
access-group 101 in interface outside
route outsdie 0.0.0.0 0.0.0.0 (your first ISP IP-gateway) track 1
route backup 0.0.0.0 0.0.0.0 (your second ISP IP-gateway) 254
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 123
 type echo protocol ipIcmpEcho (your first ISP IP-gateway) interface outsdie
 num-packets 3
 frequency 10
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
track 1 rtr 123 reachability
telnet 172.23.167.0 255.255.255.0 management
telnet 192.168.100.0 255.255.255.0 management
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 8.8.8.8 109.224.14.2
dhcpd lease 3000
dhcpd ping_timeout 30
dhcpd address (LAN-IPs) inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username admin password enVBlKK8wNBLDGaC encrypted privilege 15
prompt hostname context
Cryptochecksum:595fd9acaa06415335f11905095fbb91
: end
ciscoasa#  wr
Building configuration...
Cryptochecksum: ff4e3aad e8fe0f81 48cbb71e 3efdb239
2624 bytes copied in 3.390 secs (874 bytes/sec)
[OK]
Please rate if its helpfull
ollyahmed
version 15.2
ip cef
class skype
  set dscp ef
description TASK
ip sla 1
Thanks Ashish
Thanks Ashish
291
