Firmware update failing -- WRVS4400N
Linksys WRVS4400N
Current Firmware Version: V1.00.16
Tried updating the firmware to either of the two version you seem to have available, but fails with:
"Upgrade file is not the correct type or version for this device.  Upgrade failed.  Please obtain the correct file and try again."
Tried this one: WRVS4400Nv2_v2.0.2.1.img
And this one: WRVS4400Nv2-fw-2.0.1.3-K9.img
Then spent 2 hours trying to find how to get support for this product.
Could someone indicate where I may download the correct firmware for this product, please?  Thanks.
Everyone's tags (2)
1 ACCEPTED SOLUTION
if you have the 1.0 or 1.1 model of the WRVS4400n then you'll have to download from here
http://www.cisco.com/cisco/software/release.html?mdfid=282446893&flowid=791&softwareid=282487380&release=1.1.13&relind=AVAILABLE&rellifecycle=&reltype=latest
where it says that the highest firmware version for your model is 1.1.13.
regards
Dominik
regards
Dominik
That worked.  Thank you.
4479
