New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
forwarding HTTPS trafic not working on router RV082
Hello all,
I have problems with HTTPS trafic forwarding through 8443 port.
In fact, i can not see the https sessions on the router passing by the 8443 port.
I set the forwarding rules to the 8443 port to be forwarded to a machine connected to the router.
The values are set to default in the configuration of the router.
Thanks in advance for your support.
IGH
Everyone's tags (1)
Community Member
Hi Idris.....
Hi Idris.....
Do below configuration.
ip nat insdie source static tcp private IP ADD 443 Public IP ADD 8443
Verify.
Show Ip nat translation
Troubleshooting.
Router# terminal Monitor
Router# Debug Ip nat Translation
Adnan
Community Member
Hi Adnan,
Hi Adnan,
Thanks for your remarks.
I will test that and i will tell you the results.
Have a nice day.
Regards.
IdrissGH
Community Member
Hi Again,
Hi Again,
In fact, I tried your command "ip nat ....." but there was an error :
Object "nat" unknown, try ip help
Idriss
118
