Community Member
Gateway to Gateway Setup (RV042 & RV110W)
I am using a Cisco RV110W (Firmware 1.2.09) in a branch and I would like to create a VPN Tunnel to another site that has a Cisco RV042 (firmware
What would be the correct Configuration??
the current configuration I am using is
in the RV042 i am using
Check Enable
Local Group Setup
Local Security Gateway Type : IP Only
IP Address : RV042 Pulbic IP address
Local Security Group Type : Subnet
IP Address :
Subnet Mask :
Remote Group Setup
Remote Security Gateway Type : IP Only
IP Address :  RV110W Pulbic IP address
Remote Security Group Type : Subnet
IP Address :
Subnet Mask :
IPSec Setup
Keying Mode : IKE with Preshared Key
Phase 1 DH Group :  Group 2 - 1024 bit
Phase 1 Encryption : AES-128
Phase 1 Authentication : SHA1
Phase 1 SA Life Time : 28800 seconds
Perfect Forward Secrecy :  Check
Phase 2 DH Group : Group 2 - 1024 bit
Phase 2 Encryption : AES-128
Phase 2 Authentication : SHA1
Phase 2 SA Life Time : 3600 seconds
Preshared Key :  XXXXXXXXX (same as RV110W)
Uncheck     Aggressive Mode
Uncheck     Compress (Support IP Payload Compression Protocol(IPComp))
Uncheck     Keep-Alive
Check         AH Hash Algorithm  SHA1
Uncheck     NetBIOS Broadcast
Uncheck     NAT Traversal
Check         Dead Peer Detection Interval 10 secs
Uncheck     Tunnel Backup :
Uncheck     Split DNS :
In the RV110W  my configuration is
IKE Policy Table
Add / Edit IKE Policy Configuration
Policy Name:  XXXX
Exchange Mode: Main
IKE SA Parameters
Encryption Algorithm: AES-128
Authentication Algorithm: SHA-1
Pre-Shared Key: XXXXXXXXX (same as RV042)
Diffie-Hellman (DH) Group: Group2 (1024 bit)
SA-Lifetime: 3600 Seconds
Dead Peer Detection: Check Enable
DPD Delay: 10
DPD Timeout: 30
VPN Policy Table
Add / Edit VPN Policy Configuration
Policy Name: XXXX
Policy Type: AutoPolicy
Remote Endpoint: IP Address
(the RV042 IP address)
Local Traffic Selection
Local IP: Subnet
IP Address:
Subnet Mask:
Remote Traffic Selection
Remote IP: Subnet
IP Address:
Subnet Mask:
Manual Policy Parameters  (disable, is in Auto Mode)
SPI-Incoming: 0x
SPI-Outcoming: 0x
Encryption Algorithm: 3DES
Integrity Algorithm: SHA-1
Auto Policy Parameters
SA-Lifetime: 28800 seconds
PFS Key Group: Checked Enable
     DH Group 2 (1024 bit)
Select IKE Policy:  XXXX  (the same in previews configuration)
Can some one please tell me what I am doing wrong
