Help with setting up a VPN on a RV042
Is there any documentation out there on a step-by-step instructions on setting up a vpn on a RV042 router?
1 REPLY
Silver
Scott,
You can Google RV042 vpn setup and many links will displayed on how to set up vpn. This might be versions 1 & 2 with different looking interfaces but general setup is the same.
Also if you go to cisco.com website you also can search for RV042 setup guides. Link below was brought up using (RV042 vpn setup) @ cisco.com search.
http://www.cisco.com/en/US/docs/routers/csbr/app_notes/rv0xx_g2gvpn_an_OL-26286.pdf
Hope this helps,
Jasbryan
483
