Community Member
How add E1 to Cisco 901 series router??
To add E1 to cisco router i will use Balun converter. What will be cable type Balun RJ45 port to Router E1(RJ45 Port)???
Is it straight cable or E1 crossover cable? Please share accurate color code.
Please suggest me.
BR//
Mujahid,Bangladesh
VIP Purple
Community Member
If i use Straight cable Balun
If i use Straight cable Balun converter RJ45 Port to Router E1/T1 port is it work. or Need to use E1 cross over cable for this purpose. Please check the attachment and suggest me.
Community Member
Any update????
Any update????
BR//
Mujahid,Rangpur
112
