Community Member
How to prevent vlans from talking on WRVS4400N?
Can't seem to figure out why I can't get my two networks to quit talking to each other...hoping someone can help.
Router = WRVS4400N, firmware = V2.0.2.1
Switch = SG 200-08P, firmware = V1.0.0.16
Default vlan IP range = 10.1.0.x
Vlan 5 IP range = 10.5.0.x
I have default lan & vlan 5.
Port 4 on the router is trunked and tagged with vlan 5.
Port 8 on the switch is trunked and tagged with vlan 5.
Port 7 is connected to a server, trunked and tagged with vlan 5.
Currently my server has an IP address in the Vlan 5 range and can talk to other machines & the internet.
All appears well so far.
This is the only router and dhcp server in the network.
My problem is, I want to segregate the two networks so Vlan 5 can't see the default vlan.
I've turned off inter-vlan routing & created an ACL rule to deny as follows:
Action: Deny; Service: All; Source Interface: Any; Source IP: Net, Netmask; Destination:, Netmask
I've also reversed the IP ranges for the source and destination in case I was reading it wrong.
After disabling inter-vlan and adding the deny rule I rebooted the router.
I can still ping from one network to the other either way.
Any ideas?
