05-13-2014 11:46 AM
Hi! I would really like some help here. I am a newbie in networking and I've been hitting my head on the wall for weeks and still not able to get this done. Any help will be really appreciated!!!
I was given a task to set up a network. The requirement for the network is having two subnets that can communicate with each other. I bought two RV016 for this task. I have the RV016 set up as 192.168.1.0 and 192.168.2.0 respectively with subnet mask 255.255.255.0. Both RV016 are connected to a simple Netgear GS108 switch using the WAN switch. Both RV016 are setup as router mode and RIP enabled. Then, I have one computer connected to one RV016 and another computer connected to the other RV016. However, I am not able to ping between the two computers. What else do I need to do to get this work??
Thanks!!!!!!!
05-13-2014 08:00 PM
Hi ,
can you share me the network diagram or connectvity details of your network setup .
{LAN interface}192.168.1.0(RV016X)----> WANSWITCH----> (RV016Y)192.168.2.0{LAN Interface}
if you have connected like above , then you need to configure WAN IP address on WAN port for both RV016 X & Y device . Add those WAN subnets into your rip . Because your LAN subnets have no way connectvity to remote location . (ensure your WAN IP address are in same subnets x.x.x.x/30 or x.x.x.x/y because your WAN switch is only L2 )
Sandy.
05-14-2014 04:36 PM
Actually, I am using the LAN ports. Sorry for the mistake! Here is the network diagram:
ComputerA ----> {LAN Port 1}192.168.1.0(RV016X){LAN Port 8}
V
Netgear GS108 LAN switch
ComputerB ----> {LAN Port 1} 192.168.2.0(RV016Y){LAN Port 8}
I hope this makes things clear. Again, I am a newbie in this. So, please let me know if I missed anything or you need other information. Thank you very much!!!
05-14-2014 05:17 PM
Also, I added a static route to both router, like this:
On RV016X (192.168.1.0):
On RV016Y (192.168.2.0):
On ComputerA (192.168.1.100), I did a tracert 192.168.2.1. The trace went to 192.168.1.1 and then 192.168.2.1. But, when I did a tracert 192.168.2.100 (ComputerB), The trace went to 192.168.1.1 and then Request timed out. I don't understand why it will bypass the 192.168.2.1 and try to ping ComputerB directly. Any idea???
Thank you!!!
05-22-2014 05:17 AM
Hi leny,
You are connecting Both of your router on LAN interface (RV016Y & RV016YX) , with a help of layer 2 switch . So you cant ping directly without routing .
Configure a different Subnet like 192.168.100.1 /24 on RV016 X & 192.168.100.2 /24 on RV016Y defined it on VLAN 2 as well as on LAN port no 8 connecting to L2 Switch.
Then point static route on RV016X for reaching 192.168.2.0/24 next hop is 192.168.100.2
similarly on RV016Y for reaching 192.168.1.0/24 next hop is 192.168.100.1
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/app_notes/RV0xx_an_vlan_78-21017.pdf
Sandy
05-22-2014 02:35 AM
Okay, let me start by simply saying that nothing is right. You don't even need two rv016s to do this.
First, start by giving me a diagram or example of what the network was like before any rv016s were added. Then I'll tell you where to put the rv016 and how it needs to be configured.
