I have a Linksys WRV200 wireless router and the wireless signal is not working properly so I cannot connect to the internet wirelessly. the wireless light has a fast green blinking light. how can I fix the router?
I have a Linksys WRV200 wireless router and the wireless signal is not working properly so I am unable to connect to the internet wirelessly.  The wireless light is blinking green very quickly and I connect and disconnect from the network constantly.  How do I get the router to work properly
1 REPLY
Bronze
Hello James,
The flashing WLAN light means activity (data getting transferred). Try disconnecting all your devices and check whether the light is still flashing or disconnect the router from internet and do the check.
Do you have your SSID as linksys or the default one? If your neighbor has the same SSID, then traffic could result from your neighbor's one. Try changing your SSID and password. Make your security WPA/WPA2.
Hope this helps,
Vijay
487
