I need help configuring NAT
Hello all,
First, thank you for taking the time to read this. I am a CCNA but have very little real world experience yet. I have a client that needs me to help them to configure NAT to allow access to servers on different subnets. The scenario is for a medical center that my client has equipment in. They have a router onsite that connects directly to the other parties router. they need to configure NAT to allow people on their subnet to access an ip in their range and have it translated to the server on the other subnet. there is also a server on their subnet that will need to be accessed by the people working on the other subnet. hopefully that makes sense.
  here is what i have to work with
Inside NAT
subnet- 10.200.31.x
Fa00- 10.200.31.1
server ip- 10.200.31.50 =>NAT=> 192.168.80.50
Outside NAT
subnet- 192.168.80.
fa01- 192.168.80.2
external server IP- 192.168.80.20 =>NAT=> 10.200.31.90
Louie, Here is a good getting
Louie,
Here is a good getting started guide for NAT to give you the general idea of how it works and the configuration steps and examples:
http://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/13772-12.html
This youtube video should also help:
https://www.youtube.com/watch?v=Rs2tN6kAinU
Here is the config guide as well in case you run into any platform specific issues:
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/routconf.pdf
Hope this helps,
Wes
Louie,Below is the format for
Louie,
Below is the format for PAT:
ip dhcp excluded-address 10.200.31.50
ip dhcp pool Example
 default-router 10.200.31.1
 network 10.200.31.0 255.255.255.0
int f0/0
ip address 10.200.31.1 255.255.255.0
ip nat inside
int f0/1
ip address 192.168.80.3 255.255.255.x
ip nat outside
access-list 1 permit 10.200.31.0 0.0.0.255
ip nat inside source list 1 interface f0/1 overload
Below is the format for port forwarding:
ip nat inside source static tcp 10.200.31.50 port 192.168.80.50 port
107
