Hi every one,
I have problem in connecting my vpn clients
I have Linksys RV 082 vpn router , i have enabled the PPTP, L2TP AND IPSEC
1. I am able to connect through pptp connection, in this the ip address allocating through dhcp server
but i can't allocate on my own , even i disabled the dhcp server it works for two connection after two connection it says
735 ip address is blocked
2. I am able to connect using quick vpn succesfully , but no ipaddress is allocating for this server
becos of this i can able to ping the vpn router rest any other computer i can't use
same way local computer also unable to access the remote computer
this will be great if any bosy helps mee
thanks
john
