Linksys X2000 ADSL2+ modem router and IPTV
artbio1001
I would like to know if the Linksys X2000 ADSL2+ modem router will work with my IPTV service.
Thanks.
paolo bevilacqua
Yes, unless you IPTV provider dictates a specific router type.
Before I started using my ISP's IPTV service I was using the Thomson ST516V6 ADSL2+ modem router. But I can't get TV through this router. That's why I am asking the question. So the ISP gave me a Thomson TG784 which works fine with IPTV. The reason I want to buy another router to replace the TG784 is because the later doesn't support the IEEE 802.11n wireless standard. Which both the Linksys X2000 and X3000 do support.
Can you explain the differences between the EW and EZ versions?
Thanks.
Hi Artur,
Thank you for your question.  However, this community is for Cisco Small Business Products and the X2000 is considered a Cisco Home Product.
Here is the area that may help you further with your question.
http://homesupport.cisco.com/en-us/support/gateways/X2000
Cindy Toy
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
