Need a help || Patton + SRP527W
I have a problem to configure my connection SDSL.
my router is SRP527W.
my modem is Patton 3088.
Do I need to update the ios? or there is a specific configuration of static IP?
thanks
1 REPLY
The SRP527 is an ADSL router - presumably you want to connect to the Patton using Ethernet?  Have you used the Admin > Switch configuration to disable the DSL interface?  This will allow you to use LAN port 4 as a WAN interface - once you have done this, you can configure it as appropriate (PPP, Static IP etc).
Andy
327
