Need help. How do I config an RV082 for Dual Wan & VOIP
We have a RV082 configured with two ISP Wan connections. We recently implemented a VOIP phone system (SIP) (192.168.1.50) that is being used in appliance mode on our network. We currently have two WAN connections Load Balanced. My goal is to configure all my VOIP traffic to go out through the 1st ISP and the rest of the data through ISP #2. is this possible to achieve using the RV082? We are using a Skype SIP Trunk connection.
any help would be appreciated
1 REPLY
Silver
Yes, its possible since you are using both Wan's.Look under system management where you select dual wan/load balancing mode at the bottom there is a section called protocol binding. This section will allow you to bind certain protocol lets say VOIP out one Wan and DATA out the other as you specify it. The admin guide should have a section on protocol binding.
hope this helps,
   Jasbryan
512
