Newbie Kellindil Posts: 1 Registered: 05-16-2010 0 RV042 VPN "ignoring Delete SA payload: IPSEC SA not found (maybe expired) "
There are two RV042 in my company. The VPN works well for a long time.
WAN1(route  A)-------VPN-------WAN2(route B)
Two days ago, a new line with a  static IP was plugged into the WAN1(route B) port so that we could set  up a web server on the internet. From then on, the VPN become weird.  Sometime it works as usual, sometimes its status remains in "Waiting for  Connection".
I've checked all the settings and found no mistake.  It had worked again for about 4 hours in the morning and now the  connection failed once more. Could anyone help me with this issue?  Thanks very much.
BTW: This is part of the VPN log:
May  16 21:27:38 2010        VPN Log       Initiating Main Mode to replace  #2566
May 16 21:27:38 2010        VPN Log       [Tunnel Negotiation  Info] >>> Initiator Send Main Mode 1st packet
May 16  21:29:43 2010        VPN Log       initiating Quick Mode  PSK+ENCRYPT+TUNNEL+PFS+NAT-T to replace #2561
May 16 21:29:43 2010         VPN Log       [Tunnel Negotiation Info] >>> Initiator send  Quick Mode 1st packet
May 16 21:29:43 2010        VPN Log        [Tunnel Negotiation Info] <<< Initiator Received Quick Mode 2nd  packet
May 16 21:29:43 2010        VPN Log       [Tunnel Negotiation  Info] Inbound SPI value = 599deb56
May 16 21:29:43 2010        VPN  Log       [Tunnel Negotiation Info] Outbound SPI value = abff6c86
May  16 21:29:43 2010        VPN Log       [Tunnel Negotiation Info]  >>> Initiator Send Quick Mode 3rd packet
May 16 21:29:43  2010        VPN Log       [Tunnel Negotiation Info] Quick Mode Phase 2  SA Established, IPSec Tunnel Connected
May 16 21:29:43 2010         VPN Log       Dead Peer Detection Start, DPD delay timer=10 sec  timeout=10 sec
May 16 21:29:43 2010        VPN Log       ignoring  Delete SA payload: IPSEC SA not found (maybe expired)
May 16 21:37:33  2010        VPN Log       DPD INFO: DPD failure count = 1 DPD Retry = 3  Try DPD again!
May 16 21:37:43 2010        VPN Log       DPD INFO:  DPD failure count = 2 DPD Retry = 3 Try DPD again!
May 16 21:37:53  2010        VPN Log       DPD INFO: DPD Failure has exceed the dpd retry  count - declaring peer dead
May 16 21:37:53 2010        VPN Log        Terminating SAs using this connection
May 16 21:37:53 2010         VPN Log       Initiating Main Mode
May 16 21:37:53 2010        VPN  Log       [Tunnel Negotiation Info] >>> Initiator Send Main  Mode 1st packet
374
