No ConnTrack found
Hello I am getting many errors on my Cisco RV180 and problem with WAN connection.
Thu Oct 30 12:15:10 2014(GMT) [rv180][Kernel][KERNEL] [72527.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=99 TOS=0x00 PREC=0x00 TTL=63 ID=29171 DF PROTO=TCP SPT=35349 DPT=443 WINDOW=211 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:10 2014(GMT) [rv180][Kernel][KERNEL] [72527.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=29172 DF PROTO=TCP SPT=35349 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:10 2014(GMT) [rv180][Kernel][KERNEL] [72528.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=178.251.110.88 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=864 DF PROTO=TCP SPT=57096 DPT=38630 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:10 2014(GMT) [rv180][Kernel][KERNEL] [72528.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17649 PROTO=TCP SPT=57109 DPT=62292 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:10 2014(GMT) [rv180][Kernel][KERNEL] [72528.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=17650 PROTO=TCP SPT=57109 DPT=62292 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72529.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17651 PROTO=TCP SPT=57109 DPT=62292 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72529.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=17652 PROTO=TCP SPT=57109 DPT=62292 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72530.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14539 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72530.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=283 TOS=0x00 PREC=0x00 TTL=63 ID=14540 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72530.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=178.251.110.88 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=865 DF PROTO=TCP SPT=57096 DPT=38630 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72530.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=283 TOS=0x00 PREC=0x00 TTL=63 ID=14541 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72530.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=14542 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72530.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17653 PROTO=TCP SPT=57109 DPT=62292 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72530.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=235 TOS=0x00 PREC=0x00 TTL=63 ID=53346 DF PROTO=TCP SPT=43839 DPT=4244 WINDOW=229 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72530.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=17655 DF PROTO=TCP SPT=57109 DPT=62292 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72531.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=283 TOS=0x00 PREC=0x00 TTL=63 ID=14543 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72531.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=14544 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72531.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=17656 DF PROTO=TCP SPT=57109 DPT=62292 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=29174 DF PROTO=TCP SPT=35349 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=29175 DF PROTO=TCP SPT=35349 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=87.245.213.51 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=23803 DF PROTO=TCP SPT=35721 DPT=80 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=29176 DF PROTO=TCP SPT=35349 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=29485 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=99 TOS=0x00 PREC=0x00 TTL=63 ID=29486 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=1280 TOS=0x00 PREC=0x00 TTL=63 ID=29487 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=283 TOS=0x00 PREC=0x00 TTL=63 ID=14545 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=178.251.110.88 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=866 DF PROTO=TCP SPT=57096 DPT=38630 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.920000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=14546 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=99 TOS=0x00 PREC=0x00 TTL=63 ID=29177 DF PROTO=TCP SPT=35349 DPT=443 WINDOW=211 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72532.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=29488 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72533.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=99 TOS=0x00 PREC=0x00 TTL=63 ID=29489 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72533.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=29490 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72534.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=99 TOS=0x00 PREC=0x00 TTL=63 ID=29491 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72534.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=29492 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72535.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=53347 DF PROTO=TCP SPT=43839 DPT=4244 WINDOW=229 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72535.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=283 TOS=0x00 PREC=0x00 TTL=63 ID=14547 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72535.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=0 DF PROTO=TCP SPT=50200 DPT=443 WINDOW=386 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72536.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=14548 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72537.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=212.30.134.212 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=11122 DF PROTO=TCP SPT=60022 DPT=80 WINDOW=274 RES=0x00 ACK FIN URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72537.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=99 TOS=0x00 PREC=0x00 TTL=63 ID=29493 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:15 2014(GMT) [rv180][Kernel][KERNEL] [72537.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=29494 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:20 2014(GMT) [rv180][Kernel][KERNEL] [72540.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=53348 DF PROTO=TCP SPT=43839 DPT=4244 WINDOW=229 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:20 2014(GMT) [rv180][Kernel][KERNEL] [72541.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=283 TOS=0x00 PREC=0x00 TTL=63 ID=14550 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:20 2014(GMT) [rv180][Kernel][KERNEL] [72541.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.121 DST=193.239.68.82 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=42782 DF PROTO=TCP SPT=49676 DPT=80 WINDOW=65535 RES=0x00 ACK FIN URGP=0 MARK=0x1
Thu Oct 30 12:15:20 2014(GMT) [rv180][Kernel][KERNEL] [72542.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=235 TOS=0x00 PREC=0x00 TTL=63 ID=53349 DF PROTO=TCP SPT=43839 DPT=4244 WINDOW=229 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:20 2014(GMT) [rv180][Kernel][KERNEL] [72542.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=29495 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:20 2014(GMT) [rv180][Kernel][KERNEL] [72543.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.195 DST=64.233.167.95 LEN=99 TOS=0x00 PREC=0x00 TTL=63 ID=29496 DF PROTO=TCP SPT=42522 DPT=443 WINDOW=211 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:25 2014(GMT) [rv180][Kernel][KERNEL] [72545.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=14551 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:25 2014(GMT) [rv180][Kernel][KERNEL] [72547.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=87.245.213.51 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=23804 DF PROTO=TCP SPT=35721 DPT=80 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:25 2014(GMT) [rv180][Kernel][KERNEL] [72550.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=14552 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:31 2014(GMT) [rv180][Kernel][KERNEL] [72551.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=53350 DF PROTO=TCP SPT=43839 DPT=4244 WINDOW=229 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:31 2014(GMT) [rv180][Kernel][KERNEL] [72553.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=283 TOS=0x00 PREC=0x00 TTL=63 ID=14553 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:36 2014(GMT) [rv180][Kernel][KERNEL] [72556.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=148 TOS=0x00 PREC=0x00 TTL=127 ID=29380 DF PROTO=TCP SPT=57177 DPT=23866 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:36 2014(GMT) [rv180][Kernel][KERNEL] [72556.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=557 TOS=0x00 PREC=0x00 TTL=127 ID=29381 DF PROTO=TCP SPT=57177 DPT=23866 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:36 2014(GMT) [rv180][Kernel][KERNEL] [72557.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=557 TOS=0x00 PREC=0x00 TTL=127 ID=29382 DF PROTO=TCP SPT=57177 DPT=23866 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:36 2014(GMT) [rv180][Kernel][KERNEL] [72558.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=557 TOS=0x00 PREC=0x00 TTL=127 ID=29383 PROTO=TCP SPT=57177 DPT=23866 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:36 2014(GMT) [rv180][Kernel][KERNEL] [72559.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=29384 PROTO=TCP SPT=57177 DPT=23866 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:36 2014(GMT) [rv180][Kernel][KERNEL] [72559.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=557 TOS=0x00 PREC=0x00 TTL=127 ID=29385 PROTO=TCP SPT=57177 DPT=23866 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72560.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=14554 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72560.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=571 TOS=0x00 PREC=0x00 TTL=127 ID=29386 DF PROTO=TCP SPT=57177 DPT=23866 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72562.270000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=122 ID=15859 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RE
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72562.270000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=157 TOS=0x00 PREC=0x00 TTL=122 ID=15860 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 R
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72562.590000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=122 ID=15861 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RE
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72563.210000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=122 ID=15862 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RE
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72563.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=571 TOS=0x00 PREC=0x00 TTL=127 ID=29387 DF PROTO=TCP SPT=57177 DPT=23866 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72564.400000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=122 ID=15863 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RE
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72564.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=235 TOS=0x00 PREC=0x00 TTL=63 ID=53351 DF PROTO=TCP SPT=43839 DPT=4244 WINDOW=229 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72565.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=212.30.134.212 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=11123 DF PROTO=TCP SPT=60022 DPT=80 WINDOW=274 RES=0x00 ACK FIN URGP=0 MARK=0x1
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72565.290000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=515 TOS=0x00 PREC=0x00 TTL=122 ID=15864 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 R
Thu Oct 30 12:15:41 2014(GMT) [rv180][Kernel][KERNEL] [72565.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=29388 DF PROTO=TCP SPT=57177 DPT=23866 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:46 2014(GMT) [rv180][Kernel][KERNEL] [72565.610000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=122 ID=15865 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RE
Thu Oct 30 12:15:46 2014(GMT) [rv180][Kernel][KERNEL] [72566.810000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=122 ID=15866 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RE
Thu Oct 30 12:15:46 2014(GMT) [rv180][Kernel][KERNEL] [72568.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=651 TOS=0x00 PREC=0x00 TTL=127 ID=29390 DF PROTO=TCP SPT=57177 DPT=23866 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:46 2014(GMT) [rv180][Kernel][KERNEL] [72569.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=122 ID=15867 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RE
Thu Oct 30 12:15:51 2014(GMT) [rv180][Kernel][KERNEL] [72571.290000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=522 TOS=0x00 PREC=0x00 TTL=122 ID=15868 DF PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 R
Thu Oct 30 12:15:51 2014(GMT) [rv180][Kernel][KERNEL] [72572.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=3c:08:f6:7a:4f:1e SRC MAC=00:25:ab:48:0c:80 PAYLOAD TYPE=08:00 SRC=192.168.1.132 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=19214 DF PROTO=TCP SPT=49992 DPT=443 WINDOW=16425
Thu Oct 30 12:15:51 2014(GMT) [rv180][Kernel][KERNEL] [72573.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=53352 DF PROTO=TCP SPT=43839 DPT=4244 WINDOW=229 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:51 2014(GMT) [rv180][Kernel][KERNEL] [72574.030000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=122 ID=15869 PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RES=0
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72576.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=28405 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72576.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=28406 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72576.780000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=202 TOS=0x00 PREC=0x00 TTL=127 ID=28408 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72576.810000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=566 TOS=0x00 PREC=0x00 TTL=127 ID=28410 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72577.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=728 TOS=0x00 PREC=0x00 TTL=127 ID=28420 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72577.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=109.185.169.185 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=29391 DF PROTO=TCP SPT=57177 DPT=23866 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72577.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=28435 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72577.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=728 TOS=0x00 PREC=0x00 TTL=127 ID=28436 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72577.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=283 TOS=0x00 PREC=0x00 TTL=63 ID=14555 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72578.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=87.245.213.51 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=23805 DF PROTO=TCP SPT=35721 DPT=80 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72578.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=28444 PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72578.890000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=28448 PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72579.330000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=152 TOS=0x00 PREC=0x00 TTL=127 ID=4981 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72579.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=4982 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72579.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4983 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72579.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=28452 PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72579.860000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=173.194.44.148 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=55 ID=20955 PROTO=TCP SPT=443 DPT=34790 WINDOW=0 RES=0x
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72580.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=28454 PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72580.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=4984 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:56 2014(GMT) [rv180][Kernel][KERNEL] [72580.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4985 PROTO=TCP SPT=57251 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72581.050000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.134 DST=54.225.250.145 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=14556 DF PROTO=TCP SPT=58960 DPT=443 WINDOW=245 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72581.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=728 TOS=0x00 PREC=0x00 TTL=127 ID=28459 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72581.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4986 PROTO=TCP SPT=57251 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72581.460000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=4987 PROTO=TCP SPT=57251 DPT=37703 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72582.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=28462 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72582.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=37.1.21.16 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=122 ID=15870 PROTO=TCP SPT=44090 DPT=57199 WINDOW=256 RES=0
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72582.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4988 PROTO=TCP SPT=57251 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72582.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=4989 PROTO=TCP SPT=57251 DPT=37703 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72583.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=728 TOS=0x00 PREC=0x00 TTL=127 ID=28469 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:01 2014(GMT) [rv180][Kernel][KERNEL] [72583.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4990 PROTO=TCP SPT=57251 DPT=37703 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:02 2014(GMT) [rv180][Kernel][KERNEL] [72583.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=4992 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:02 2014(GMT) [rv180][Kernel][KERNEL] [72586.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4993 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:07 2014(GMT) [rv180][Kernel][KERNEL] [72586.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=4994 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:07 2014(GMT) [rv180][Kernel][KERNEL] [72586.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=28487 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:07 2014(GMT) [rv180][Kernel][KERNEL] [72588.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=728 TOS=0x00 PREC=0x00 TTL=127 ID=28548 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:07 2014(GMT) [rv180][Kernel][KERNEL] [72591.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=4995 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:07 2014(GMT) [rv180][Kernel][KERNEL] [72591.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=4996 DF PROTO=TCP SPT=57251 DPT=37703 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:12 2014(GMT) [rv180][Kernel][KERNEL] [72593.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.141 DST=212.42.76.151 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=28606 DF PROTO=TCP SPT=50571 DPT=443 WINDOW=16425 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:17 2014(GMT) [rv180][Kernel][KERNEL] [72600.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=32004 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:17 2014(GMT) [rv180][Kernel][KERNEL] [72601.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=19559 DF PROTO=TCP SPT=50011 DPT=443 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:17 2014(GMT) [rv180][Kernel][KERNEL] [72601.610000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=414 TOS=0x00 PREC=0x00 TTL=127 ID=19560 DF PROTO=TCP SPT=50011 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72601.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=19561 DF PROTO=TCP SPT=50011 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72601.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=19595 DF PROTO=TCP SPT=50011 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72601.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=414 TOS=0x00 PREC=0x00 TTL=127 ID=19599 DF PROTO=TCP SPT=50011 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72602.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=20647 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72602.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=19600 DF PROTO=TCP SPT=50011 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72602.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=414 TOS=0x00 PREC=0x00 TTL=127 ID=19601 DF PROTO=TCP SPT=50011 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72603.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=19602 PROTO=TCP SPT=50011 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72603.220000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=36417 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72603.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=23.59.84.214 LEN=414 TOS=0x00 PREC=0x00 TTL=127 ID=19603 PROTO=TCP SPT=50011 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72605.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=44652 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:22 2014(GMT) [rv180][Kernel][KERNEL] [72606.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.121 DST=193.239.68.82 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=47995 DF PROTO=TCP SPT=49676 DPT=80 WINDOW=65535 RES=0x00 ACK FIN URGP=0 MARK=0x1
Thu Oct 30 12:16:27 2014(GMT) [rv180][Kernel][KERNEL] [72609.480000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=55171 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:27 2014(GMT) [rv180][Kernel][KERNEL] [72610.290000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=123 TOS=0x00 PREC=0x00 TTL=127 ID=17674 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:27 2014(GMT) [rv180][Kernel][KERNEL] [72610.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=17675 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:27 2014(GMT) [rv180][Kernel][KERNEL] [72610.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17676 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:27 2014(GMT) [rv180][Kernel][KERNEL] [72611.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17677 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:27 2014(GMT) [rv180][Kernel][KERNEL] [72611.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=17678 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:32 2014(GMT) [rv180][Kernel][KERNEL] [72612.390000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17679 PROTO=TCP SPT=57349 DPT=62292 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:32 2014(GMT) [rv180][Kernel][KERNEL] [72612.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=17680 PROTO=TCP SPT=57349 DPT=62292 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:32 2014(GMT) [rv180][Kernel][KERNEL] [72613.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=217.69.141.144 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=17107 DF PROTO=TCP SPT=53149 DPT=443 WINDOW=0 RES=0x00 ACK RST URGP=0 MARK=0x1
Thu Oct 30 12:16:32 2014(GMT) [rv180][Kernel][KERNEL] [72613.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=185.5.137.183 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=8252 DF PROTO=TCP SPT=53146 DPT=443 WINDOW=0 RES=0x00 ACK RST URGP=0 MARK=0x1
Thu Oct 30 12:16:32 2014(GMT) [rv180][Kernel][KERNEL] [72613.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=17681 PROTO=TCP SPT=57349 DPT=62292 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:32 2014(GMT) [rv180][Kernel][KERNEL] [72614.790000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17682 PROTO=TCP SPT=57349 DPT=62292 WINDOW=260 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:32 2014(GMT) [rv180][Kernel][KERNEL] [72614.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=17684 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:37 2014(GMT) [rv180][Kernel][KERNEL] [72617.220000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=17685 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:37 2014(GMT) [rv180][Kernel][KERNEL] [72617.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=62189 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:37 2014(GMT) [rv180][Kernel][KERNEL] [72619.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17686 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=260 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:37 2014(GMT) [rv180][Kernel][KERNEL] [72621.730000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=54.225.250.145 DST=91.235.71.14 LEN=64 TOS=0x00 PREC=0x00 TTL=44 ID=41950 DF PROTO=TCP SPT=443 DPT=58960 WINDOW=122 R
Thu Oct 30 12:16:37 2014(GMT) [rv180][Kernel][KERNEL] [72622.120000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=17687 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:42 2014(GMT) [rv180][Kernel][KERNEL] [72622.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=17688 DF PROTO=TCP SPT=57349 DPT=62292 WINDOW=260 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:43 2014(GMT) [rv180][Kernel][KERNEL] [72627.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=152 TOS=0x00 PREC=0x00 TTL=127 ID=15677 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72627.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=15678 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72627.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=15679 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72627.740000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=36159 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72628.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=15680 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72628.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=15681 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72629.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=15682 PROTO=TCP SPT=57397 DPT=18549 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72629.510000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=15683 PROTO=TCP SPT=57397 DPT=18549 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72630.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=19763 DF PROTO=TCP SPT=50020 DPT=443 WINDOW=64240 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72630.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19764 DF PROTO=TCP SPT=50020 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72630.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19772 DF PROTO=TCP SPT=50020 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72630.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=15684 PROTO=TCP SPT=57397 DPT=18549 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72630.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=15685 PROTO=TCP SPT=57397 DPT=18549 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72631.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19773 DF PROTO=TCP SPT=50020 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72631.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=15686 PROTO=TCP SPT=57397 DPT=18549 WINDOW=260 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:48 2014(GMT) [rv180][Kernel][KERNEL] [72631.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=15688 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:53 2014(GMT) [rv180][Kernel][KERNEL] [72632.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19779 PROTO=TCP SPT=50020 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:53 2014(GMT) [rv180][Kernel][KERNEL] [72633.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=19780 PROTO=TCP SPT=50020 DPT=443 WINDOW=62816 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:53 2014(GMT) [rv180][Kernel][KERNEL] [72634.280000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=15689 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=260 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:53 2014(GMT) [rv180][Kernel][KERNEL] [72634.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=15690 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:53 2014(GMT) [rv180][Kernel][KERNEL] [72634.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19781 PROTO=TCP SPT=50020 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:53 2014(GMT) [rv180][Kernel][KERNEL] [72635.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19784 DF PROTO=TCP SPT=50020 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:58 2014(GMT) [rv180][Kernel][KERNEL] [72639.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=15691 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=260 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:58 2014(GMT) [rv180][Kernel][KERNEL] [72639.110000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=92.248.247.117 LEN=734 TOS=0x00 PREC=0x00 TTL=127 ID=15692 DF PROTO=TCP SPT=57397 DPT=18549 WINDOW=260 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:16:58 2014(GMT) [rv180][Kernel][KERNEL] [72643.020000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=19813 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=64240 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:16:58 2014(GMT) [rv180][Kernel][KERNEL] [72643.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19814 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:03 2014(GMT) [rv180][Kernel][KERNEL] [72643.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19815 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:03 2014(GMT) [rv180][Kernel][KERNEL] [72644.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19816 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:03 2014(GMT) [rv180][Kernel][KERNEL] [72645.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19818 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:03 2014(GMT) [rv180][Kernel][KERNEL] [72646.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=19819 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:03 2014(GMT) [rv180][Kernel][KERNEL] [72646.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=153 TOS=0x00 PREC=0x00 TTL=127 ID=13514 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:03 2014(GMT) [rv180][Kernel][KERNEL] [72646.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=13515 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:04 2014(GMT) [rv180][Kernel][KERNEL] [72646.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=507 TOS=0x00 PREC=0x00 TTL=127 ID=13516 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:04 2014(GMT) [rv180][Kernel][KERNEL] [72646.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=620 TOS=0x00 PREC=0x00 TTL=127 ID=13517 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:04 2014(GMT) [rv180][Kernel][KERNEL] [72647.220000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=13518 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:04 2014(GMT) [rv180][Kernel][KERNEL] [72647.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=634 TOS=0x00 PREC=0x00 TTL=127 ID=13519 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:04 2014(GMT) [rv180][Kernel][KERNEL] [72648.130000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=62845 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72648.420000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=13520 PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72648.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=13521 PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72649.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19827 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72649.620000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=13522 PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72649.650000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=13523 PROTO=TCP SPT=57455 DPT=60317 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72650.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=13524 PROTO=TCP SPT=57455 DPT=60317 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72650.850000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=634 TOS=0x00 PREC=0x00 TTL=127 ID=13526 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72653.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=41 TOS=0x00 PREC=0x00 TTL=127 ID=19842 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72653.220000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=13527 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:09 2014(GMT) [rv180][Kernel][KERNEL] [72653.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=634 TOS=0x00 PREC=0x00 TTL=127 ID=13528 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72654.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=41 TOS=0x00 PREC=0x00 TTL=127 ID=19845 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72655.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=41 TOS=0x00 PREC=0x00 TTL=127 ID=19846 DF PROTO=TCP SPT=50022 DPT=443 WINDOW=62816 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72655.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=19859 DF PROTO=TCP SPT=50023 DPT=443 WINDOW=64240 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72656.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19860 DF PROTO=TCP SPT=50023 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72656.400000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19861 DF PROTO=TCP SPT=50023 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72657.200000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19865 DF PROTO=TCP SPT=50023 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72658.050000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=13529 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72658.070000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=37.140.83.68 LEN=634 TOS=0x00 PREC=0x00 TTL=127 ID=13530 DF PROTO=TCP SPT=57455 DPT=60317 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:14 2014(GMT) [rv180][Kernel][KERNEL] [72658.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19872 DF PROTO=TCP SPT=50023 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:19 2014(GMT) [rv180][Kernel][KERNEL] [72658.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=19873 DF PROTO=TCP SPT=50023 DPT=443 WINDOW=62816 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:19 2014(GMT) [rv180][Kernel][KERNEL] [72662.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=173.37.144.211 LEN=350 TOS=0x00 PREC=0x00 TTL=127 ID=19881 DF PROTO=TCP SPT=50023 DPT=443 WINDOW=62816 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:24 2014(GMT) [rv180][Kernel][KERNEL] [72664.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=147 TOS=0x00 PREC=0x00 TTL=127 ID=26953 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:24 2014(GMT) [rv180][Kernel][KERNEL] [72664.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=26954 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:24 2014(GMT) [rv180][Kernel][KERNEL] [72664.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=525 TOS=0x00 PREC=0x00 TTL=127 ID=26955 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:24 2014(GMT) [rv180][Kernel][KERNEL] [72664.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=26956 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:24 2014(GMT) [rv180][Kernel][KERNEL] [72665.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=26957 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:25 2014(GMT) [rv180][Kernel][KERNEL] [72665.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=26958 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:25 2014(GMT) [rv180][Kernel][KERNEL] [72666.340000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=26959 PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:25 2014(GMT) [rv180][Kernel][KERNEL] [72666.380000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=26960 PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:25 2014(GMT) [rv180][Kernel][KERNEL] [72667.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=26961 PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:25 2014(GMT) [rv180][Kernel][KERNEL] [72667.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=26962 PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:25 2014(GMT) [rv180][Kernel][KERNEL] [72668.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=27064 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:25 2014(GMT) [rv180][Kernel][KERNEL] [72668.750000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=26963 PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:25 2014(GMT) [rv180][Kernel][KERNEL] [72668.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=26964 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:30 2014(GMT) [rv180][Kernel][KERNEL] [72670.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.121 DST=193.239.68.82 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=20651 DF PROTO=TCP SPT=49676 DPT=80 WINDOW=65535 RES=0x00 ACK FIN URGP=0 MARK=0x1
Thu Oct 30 12:17:30 2014(GMT) [rv180][Kernel][KERNEL] [72671.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=26965 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:30 2014(GMT) [rv180][Kernel][KERNEL] [72671.210000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=26967 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:35 2014(GMT) [rv180][Kernel][KERNEL] [72675.950000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=26968 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:35 2014(GMT) [rv180][Kernel][KERNEL] [72676.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=26969 DF PROTO=TCP SPT=57501 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:45 2014(GMT) [rv180][Kernel][KERNEL] [72685.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.211 DST=54.225.251.238 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=22542 DF PROTO=TCP SPT=38078 DPT=4244 WINDOW=1024 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:45 2014(GMT) [rv180][Kernel][KERNEL] [72685.190000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.211 DST=54.225.251.238 LEN=64 TOS=0x00 PREC=0x00 TTL=63 ID=22543 DF PROTO=TCP SPT=38078 DPT=4244 WINDOW=1024 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:17:45 2014(GMT) [rv180][Kernel][KERNEL] [72688.870000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=31518 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:17:55 2014(GMT) [rv180][Kernel][KERNEL] [72699.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=5021 DF PROTO=TCP SPT=57608 DPT=37703 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:05 2014(GMT) [rv180][Kernel][KERNEL] [72706.170000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.100.180.90 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=62641 DF PROTO=TCP SPT=993 DPT=55013 WINDOW=36 RES
Thu Oct 30 12:18:05 2014(GMT) [rv180][Kernel][KERNEL] [72708.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=20544 DF PROTO=TCP SPT=50033 DPT=443 WINDOW=256 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:05 2014(GMT) [rv180][Kernel][KERNEL] [72708.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20545 DF PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:05 2014(GMT) [rv180][Kernel][KERNEL] [72709.230000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=9987 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:05 2014(GMT) [rv180][Kernel][KERNEL] [72709.320000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20575 DF PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:05 2014(GMT) [rv180][Kernel][KERNEL] [72710.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20661 DF PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:10 2014(GMT) [rv180][Kernel][KERNEL] [72711.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20662 PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:10 2014(GMT) [rv180][Kernel][KERNEL] [72711.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.211 DST=54.225.251.238 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=4385 DF PROTO=TCP SPT=38079 DPT=4244 WINDOW=1024 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:10 2014(GMT) [rv180][Kernel][KERNEL] [72711.970000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=20663 PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:10 2014(GMT) [rv180][Kernel][KERNEL] [72712.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20665 PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:11 2014(GMT) [rv180][Kernel][KERNEL] [72714.080000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20668 DF PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:16 2014(GMT) [rv180][Kernel][KERNEL] [72716.720000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.100.180.90 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=56796 DF PROTO=TCP SPT=993 DPT=55014 WINDOW=34 RES
Thu Oct 30 12:18:16 2014(GMT) [rv180][Kernel][KERNEL] [72716.800000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20674 DF PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:16 2014(GMT) [rv180][Kernel][KERNEL] [72718.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=20679 DF PROTO=TCP SPT=50033 DPT=443 WINDOW=255 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:16 2014(GMT) [rv180][Kernel][KERNEL] [72719.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=20686 DF PROTO=TCP SPT=50035 DPT=443 WINDOW=64240 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:16 2014(GMT) [rv180][Kernel][KERNEL] [72719.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20687 DF PROTO=TCP SPT=50035 DPT=443 WINDOW=63827 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:16 2014(GMT) [rv180][Kernel][KERNEL] [72719.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20694 DF PROTO=TCP SPT=50035 DPT=443 WINDOW=63827 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:16 2014(GMT) [rv180][Kernel][KERNEL] [72720.300000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20695 DF PROTO=TCP SPT=50035 DPT=443 WINDOW=63827 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:16 2014(GMT) [rv180][Kernel][KERNEL] [72720.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=153 TOS=0x00 PREC=0x00 TTL=127 ID=8450 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72720.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8451 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72720.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=519 TOS=0x00 PREC=0x00 TTL=127 ID=8452 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72720.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=8453 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72721.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8454 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72721.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20696 DF PROTO=TCP SPT=50035 DPT=443 WINDOW=63827 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72721.710000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=8455 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72722.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=20697 DF PROTO=TCP SPT=50035 DPT=443 WINDOW=63827 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72722.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8456 PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72723.350000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=8457 PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72723.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8458 PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72724.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.132 DST=50.31.164.166 LEN=354 TOS=0x00 PREC=0x00 TTL=127 ID=20701 DF PROTO=TCP SPT=50035 DPT=443 WINDOW=63827 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72724.910000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8459 PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:21 2014(GMT) [rv180][Kernel][KERNEL] [72725.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=576 TOS=0x00 PREC=0x00 TTL=127 ID=8460 PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:26 2014(GMT) [rv180][Kernel][KERNEL] [72726.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=8461 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:26 2014(GMT) [rv180][Kernel][KERNEL] [72727.310000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8462 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:26 2014(GMT) [rv180][Kernel][KERNEL] [72729.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=50659 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:26 2014(GMT) [rv180][Kernel][KERNEL] [72729.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=8464 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:32 2014(GMT) [rv180][Kernel][KERNEL] [72732.140000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=8465 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:32 2014(GMT) [rv180][Kernel][KERNEL] [72733.440000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=109.185.169.185 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=119 ID=3642 DF PROTO=TCP SPT=23866 DPT=57177 WINDOW=0
Thu Oct 30 12:18:32 2014(GMT) [rv180][Kernel][KERNEL] [72733.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.251 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=12577 DF PROTO=TCP SPT=53158 DPT=443 WINDOW=0 RES=0x00 ACK RST URGP=0 MARK=0x1
Thu Oct 30 12:18:32 2014(GMT) [rv180][Kernel][KERNEL] [72733.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.38 LEN=87 TOS=0x00 PREC=0x00 TTL=127 ID=32226 DF PROTO=TCP SPT=53167 DPT=443 WINDOW=1023 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:32 2014(GMT) [rv180][Kernel][KERNEL] [72733.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.38 LEN=87 TOS=0x00 PREC=0x00 TTL=127 ID=32227 DF PROTO=TCP SPT=53167 DPT=443 WINDOW=1023 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:32 2014(GMT) [rv180][Kernel][KERNEL] [72734.450000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.38 LEN=87 TOS=0x00 PREC=0x00 TTL=127 ID=32228 DF PROTO=TCP SPT=53167 DPT=443 WINDOW=1023 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:32 2014(GMT) [rv180][Kernel][KERNEL] [72735.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.121 DST=193.239.68.82 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=18056 DF PROTO=TCP SPT=49676 DPT=80 WINDOW=65535 RES=0x00 ACK FIN URGP=0 MARK=0x1
Thu Oct 30 12:18:32 2014(GMT) [rv180][Kernel][KERNEL] [72735.640000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.38 LEN=87 TOS=0x00 PREC=0x00 TTL=127 ID=32229 DF PROTO=TCP SPT=53167 DPT=443 WINDOW=1023 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:37 2014(GMT) [rv180][Kernel][KERNEL] [72736.490000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=95.170.96.211 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=8466 DF PROTO=TCP SPT=57672 DPT=12386 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:37 2014(GMT) [rv180][Kernel][KERNEL] [72736.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.38 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=32230 DF PROTO=TCP SPT=53167 DPT=443 WINDOW=1023 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:37 2014(GMT) [rv180][Kernel][KERNEL] [72738.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.38 LEN=87 TOS=0x00 PREC=0x00 TTL=127 ID=32231 DF PROTO=TCP SPT=53167 DPT=443 WINDOW=1023 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:42 2014(GMT) [rv180][Kernel][KERNEL] [72742.540000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.38 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=32232 DF PROTO=TCP SPT=53167 DPT=443 WINDOW=1023 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:42 2014(GMT) [rv180][Kernel][KERNEL] [72742.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.20 DST=94.100.187.38 LEN=87 TOS=0x00 PREC=0x00 TTL=127 ID=32233 DF PROTO=TCP SPT=53167 DPT=443 WINDOW=1023 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:47 2014(GMT) [rv180][Kernel][KERNEL] [72749.960000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.172.239.21 LEN=142 TOS=0x00 PREC=0x00 TTL=63 ID=32099 DF PROTO=TCP SPT=49878 DPT=5223 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:47 2014(GMT) [rv180][Kernel][KERNEL] [72751.410000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=138 TOS=0x00 PREC=0x00 TTL=127 ID=5028 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:47 2014(GMT) [rv180][Kernel][KERNEL] [72751.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=5029 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:47 2014(GMT) [rv180][Kernel][KERNEL] [72751.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=5030 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:52 2014(GMT) [rv180][Kernel][KERNEL] [72752.440000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=5031 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:52 2014(GMT) [rv180][Kernel][KERNEL] [72752.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=5032 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:52 2014(GMT) [rv180][Kernel][KERNEL] [72753.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=5043 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:52 2014(GMT) [rv180][Kernel][KERNEL] [72754.010000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=5044 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:52 2014(GMT) [rv180][Kernel][KERNEL] [72756.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=5045 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:18:52 2014(GMT) [rv180][Kernel][KERNEL] [72756.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=148 TOS=0x00 PREC=0x00 TTL=127 ID=5046 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:53 2014(GMT) [rv180][Kernel][KERNEL] [72756.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=754 TOS=0x00 PREC=0x00 TTL=127 ID=5048 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:18:58 2014(GMT) [rv180][Kernel][KERNEL] [72758.510000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=46.159.123.179 DST=91.235.71.14 LEN=121 TOS=0x00 PREC=0x00 TTL=119 ID=5374 DF PROTO=TCP SPT=11120 DPT=57761 WINDOW=25
Thu Oct 30 12:18:58 2014(GMT) [rv180][Kernel][KERNEL] [72759.190000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=46.159.123.179 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=119 ID=5375 DF PROTO=TCP SPT=11120 DPT=57761 WINDOW=256
Thu Oct 30 12:18:58 2014(GMT) [rv180][Kernel][KERNEL] [72759.310000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=46.159.123.179 DST=91.235.71.14 LEN=530 TOS=0x00 PREC=0x00 TTL=119 ID=5376 DF PROTO=TCP SPT=11120 DPT=57761 WINDOW=25
Thu Oct 30 12:18:58 2014(GMT) [rv180][Kernel][KERNEL] [72761.690000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=5049 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:03 2014(GMT) [rv180][Kernel][KERNEL] [72762.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=754 TOS=0x00 PREC=0x00 TTL=127 ID=5050 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:03 2014(GMT) [rv180][Kernel][KERNEL] [72762.750000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=161.69.12.13 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=53711 DF PROTO=TCP SPT=80 DPT=57770 WINDOW=4380 RE
Thu Oct 30 12:19:03 2014(GMT) [rv180][Kernel][KERNEL] [72763.520000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=46.72.2.157 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=5051 DF PROTO=TCP SPT=57746 DPT=37703 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72771.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=63639 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8054 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72771.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=4146 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8046 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72771.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=825 TOS=0x00 PREC=0x00 TTL=63 ID=37409 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72771.760000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=325 TOS=0x00 PREC=0x00 TTL=63 ID=42325 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72772.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=38378 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4050 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72772.590000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=37656 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4043 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72772.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=127 TOS=0x00 PREC=0x00 TTL=63 ID=34174 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72772.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=58 TOS=0x00 PREC=0x00 TTL=63 ID=3755 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72772.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=137 TOS=0x00 PREC=0x00 TTL=63 ID=63070 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:08 2014(GMT) [rv180][Kernel][KERNEL] [72772.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=121 TOS=0x00 PREC=0x00 TTL=63 ID=60747 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:13 2014(GMT) [rv180][Kernel][KERNEL] [72773.000000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=47262 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:13 2014(GMT) [rv180][Kernel][KERNEL] [72773.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=1098 TOS=0x00 PREC=0x00 TTL=63 ID=46173 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:13 2014(GMT) [rv180][Kernel][KERNEL] [72773.430000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=61069 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:13 2014(GMT) [rv180][Kernel][KERNEL] [72773.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=287 TOS=0x00 PREC=0x00 TTL=63 ID=49241 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72773.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=16823 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72774.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=287 TOS=0x00 PREC=0x00 TTL=63 ID=6153 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72775.090000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=1098 TOS=0x00 PREC=0x00 TTL=63 ID=11301 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72775.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=139 TOS=0x00 PREC=0x00 TTL=127 ID=26996 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72775.550000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=26997 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=256 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72775.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=26998 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72776.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=48619 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72776.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=632 TOS=0x00 PREC=0x00 TTL=127 ID=26999 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72776.160000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=27000 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72776.880000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=50581 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72777.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=27001 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72777.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=27002 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:14 2014(GMT) [rv180][Kernel][KERNEL] [72777.600000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=287 TOS=0x00 PREC=0x00 TTL=63 ID=31354 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72778.570000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=27003 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72779.100000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=13101 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72779.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=27004 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72779.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=27005 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72779.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=1098 TOS=0x00 PREC=0x00 TTL=63 ID=19834 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72780.260000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=305 TOS=0x00 PREC=0x00 TTL=127 ID=61581 DF PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72781.680000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61592 DF PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72782.030000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=287 TOS=0x00 PREC=0x00 TTL=63 ID=55192 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:19 2014(GMT) [rv180][Kernel][KERNEL] [72782.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=27006 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:20 2014(GMT) [rv180][Kernel][KERNEL] [72782.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=305 TOS=0x00 PREC=0x00 TTL=127 ID=61593 DF PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:20 2014(GMT) [rv180][Kernel][KERNEL] [72782.830000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61594 DF PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:20 2014(GMT) [rv180][Kernel][KERNEL] [72783.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=19561 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72784.580000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=134.17.130.59 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=27008 DF PROTO=TCP SPT=57799 DPT=64884 WINDOW=254 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72784.940000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61595 DF PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72785.530000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=5679 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72787.270000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=118 ID=7551 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=19
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72787.270000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=124 TOS=0x00 PREC=0x00 TTL=118 ID=7552 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=1
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72787.570000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=7553 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=19
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72787.570000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=625 TOS=0x00 PREC=0x00 TTL=118 ID=7554 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=1
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72787.660000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=305 TOS=0x00 PREC=0x00 TTL=127 ID=61596 DF PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72788.160000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=625 TOS=0x00 PREC=0x00 TTL=118 ID=7555 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=1
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72788.180000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=7556 PROTO=TCP SPT=63858 DPT=57839 WINDOW=195 R
Thu Oct 30 12:19:25 2014(GMT) [rv180][Kernel][KERNEL] [72788.930000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61597 DF PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:26 2014(GMT) [rv180][Kernel][KERNEL] [72789.370000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=576 TOS=0x00 PREC=0x00 TTL=118 ID=7557 PROTO=TCP SPT=63858 DPT=57839 WINDOW=195
Thu Oct 30 12:19:26 2014(GMT) [rv180][Kernel][KERNEL] [72789.390000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=7558 PROTO=TCP SPT=63858 DPT=57839 WINDOW=195 R
Thu Oct 30 12:19:26 2014(GMT) [rv180][Kernel][KERNEL] [72789.480000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.215 DST=17.110.230.16 LEN=1098 TOS=0x00 PREC=0x00 TTL=63 ID=54976 DF PROTO=TCP SPT=49884 DPT=443 WINDOW=8192 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:31 2014(GMT) [rv180][Kernel][KERNEL] [72790.570000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=576 TOS=0x00 PREC=0x00 TTL=118 ID=7559 PROTO=TCP SPT=63858 DPT=57839 WINDOW=195
Thu Oct 30 12:19:31 2014(GMT) [rv180][Kernel][KERNEL] [72790.580000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=7560 PROTO=TCP SPT=63858 DPT=57839 WINDOW=195 R
Thu Oct 30 12:19:31 2014(GMT) [rv180][Kernel][KERNEL] [72791.150000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=287 TOS=0x00 PREC=0x00 TTL=63 ID=826 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:31 2014(GMT) [rv180][Kernel][KERNEL] [72791.770000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=632 TOS=0x00 PREC=0x00 TTL=118 ID=7561 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=1
Thu Oct 30 12:19:31 2014(GMT) [rv180][Kernel][KERNEL] [72791.790000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=7562 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=19
Thu Oct 30 12:19:31 2014(GMT) [rv180][Kernel][KERNEL] [72794.170000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=632 TOS=0x00 PREC=0x00 TTL=118 ID=7563 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=1
Thu Oct 30 12:19:31 2014(GMT) [rv180][Kernel][KERNEL] [72794.210000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=7564 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=19
Thu Oct 30 12:19:36 2014(GMT) [rv180][Kernel][KERNEL] [72796.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61606 DF PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:36 2014(GMT) [rv180][Kernel][KERNEL] [72797.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=305 TOS=0x00 PREC=0x00 TTL=127 ID=61608 PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:19:36 2014(GMT) [rv180][Kernel][KERNEL] [72798.840000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=24468 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:36 2014(GMT) [rv180][Kernel][KERNEL] [72798.970000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=632 TOS=0x00 PREC=0x00 TTL=118 ID=7565 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=1
Thu Oct 30 12:19:36 2014(GMT) [rv180][Kernel][KERNEL] [72799.010000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=118 ID=7566 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=19
Thu Oct 30 12:19:37 2014(GMT) [rv180][Kernel][KERNEL] [72800.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.121 DST=193.239.68.82 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=39134 DF PROTO=TCP SPT=49676 DPT=80 WINDOW=65535 RES=0x00 ACK FIN URGP=0 MARK=0x1
Thu Oct 30 12:19:42 2014(GMT) [rv180][Kernel][KERNEL] [72802.560000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.125 DST=173.252.100.27 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=5680 DF PROTO=TCP SPT=55017 DPT=443 WINDOW=4096 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:42 2014(GMT) [rv180][Kernel][KERNEL] [72803.250000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61618 DF PROTO=TCP SPT=2135 DPT=443 WINDOW=17279 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:42 2014(GMT) [rv180][Kernel][KERNEL] [72806.250000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=54.225.251.238 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=44 ID=55675 DF PROTO=TCP SPT=4244 DPT=38079 WINDOW=115
Thu Oct 30 12:19:47 2014(GMT) [rv180][Kernel][KERNEL] [72807.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=188.242.160.106 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=118 ID=7567 DF PROTO=TCP SPT=63858 DPT=57839 WINDOW=19
Thu Oct 30 12:19:47 2014(GMT) [rv180][Kernel][KERNEL] [72807.700000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61624 PROTO=TCP SPT=2132 DPT=443 WINDOW=17380 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:47 2014(GMT) [rv180][Kernel][KERNEL] [72807.950000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=54.225.250.158 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=44 ID=47184 DF PROTO=TCP SPT=4244 DPT=48309 WINDOW=114
Thu Oct 30 12:19:47 2014(GMT) [rv180][Kernel][KERNEL] [72809.170000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61627 DF PROTO=TCP SPT=2135 DPT=443 WINDOW=17279 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:57 2014(GMT) [rv180][Kernel][KERNEL] [72816.980000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61636 DF PROTO=TCP SPT=2135 DPT=443 WINDOW=17279 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:19:57 2014(GMT) [rv180][Kernel][KERNEL] [72819.770000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61640 PROTO=TCP SPT=2132 DPT=443 WINDOW=0 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:02 2014(GMT) [rv180][Kernel][KERNEL] [72824.300000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=137 TOS=0x00 PREC=0x00 TTL=117 ID=16092 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=25
Thu Oct 30 12:20:02 2014(GMT) [rv180][Kernel][KERNEL] [72824.300000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=117 ID=16093 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=256
Thu Oct 30 12:20:02 2014(GMT) [rv180][Kernel][KERNEL] [72824.600000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=16346 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=256
Thu Oct 30 12:20:02 2014(GMT) [rv180][Kernel][KERNEL] [72824.610000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=665 TOS=0x00 PREC=0x00 TTL=117 ID=16373 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=25
Thu Oct 30 12:20:02 2014(GMT) [rv180][Kernel][KERNEL] [72825.210000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=665 TOS=0x00 PREC=0x00 TTL=117 ID=16940 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=25
Thu Oct 30 12:20:02 2014(GMT) [rv180][Kernel][KERNEL] [72825.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=16969 PROTO=TCP SPT=46062 DPT=57916 WINDOW=256 RE
Thu Oct 30 12:20:02 2014(GMT) [rv180][Kernel][KERNEL] [72826.400000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=576 TOS=0x00 PREC=0x00 TTL=117 ID=18367 PROTO=TCP SPT=46062 DPT=57916 WINDOW=256 R
Thu Oct 30 12:20:03 2014(GMT) [rv180][Kernel][KERNEL] [72826.410000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=18370 PROTO=TCP SPT=46062 DPT=57916 WINDOW=256 RE
Thu Oct 30 12:20:08 2014(GMT) [rv180][Kernel][KERNEL] [72827.610000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=576 TOS=0x00 PREC=0x00 TTL=117 ID=19776 PROTO=TCP SPT=46062 DPT=57916 WINDOW=256 R
Thu Oct 30 12:20:08 2014(GMT) [rv180][Kernel][KERNEL] [72827.610000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=19777 PROTO=TCP SPT=46062 DPT=57916 WINDOW=256 RE
Thu Oct 30 12:20:08 2014(GMT) [rv180][Kernel][KERNEL] [72828.800000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=665 TOS=0x00 PREC=0x00 TTL=117 ID=20741 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=25
Thu Oct 30 12:20:08 2014(GMT) [rv180][Kernel][KERNEL] [72828.820000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=20764 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=256
Thu Oct 30 12:20:08 2014(GMT) [rv180][Kernel][KERNEL] [72829.240000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61646 DF PROTO=TCP SPT=2135 DPT=443 WINDOW=17279 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:08 2014(GMT) [rv180][Kernel][KERNEL] [72831.200000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=672 TOS=0x00 PREC=0x00 TTL=117 ID=22909 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=25
Thu Oct 30 12:20:08 2014(GMT) [rv180][Kernel][KERNEL] [72831.220000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=22923 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=256
Thu Oct 30 12:20:13 2014(GMT) [rv180][Kernel][KERNEL] [72836.000000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=672 TOS=0x00 PREC=0x00 TTL=117 ID=29276 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=25
Thu Oct 30 12:20:13 2014(GMT) [rv180][Kernel][KERNEL] [72836.020000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=52 TOS=0x00 PREC=0x00 TTL=117 ID=29291 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=256
Thu Oct 30 12:20:13 2014(GMT) [rv180][Kernel][KERNEL] [72836.050000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61647 PROTO=TCP SPT=2135 DPT=443 WINDOW=0 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:23 2014(GMT) [rv180][Kernel][KERNEL] [72843.720000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61669 PROTO=TCP SPT=2132 DPT=443 WINDOW=0 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:23 2014(GMT) [rv180][Kernel][KERNEL] [72844.200000] NO CONNTRACK FOUND [DROP]IN=eth1 OUT= DST MAC=3c:08:f6:7a:4f:1f SRC MAC=60:eb:69:db:f6:89 PAYLOAD TYPE=08:00 SRC=94.188.31.195 DST=91.235.71.14 LEN=40 TOS=0x00 PREC=0x00 TTL=117 ID=6388 DF PROTO=TCP SPT=46062 DPT=57916 WINDOW=256
Thu Oct 30 12:20:34 2014(GMT) [rv180][Kernel][KERNEL] [72854.040000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT= DST MAC=3c:08:f6:7a:4f:1e SRC MAC=00:25:ab:48:0c:80 PAYLOAD TYPE=08:00 SRC=192.168.1.132 DST=192.168.1.1 LEN=40 TOS=0x00 PREC=0x00 TTL=128 ID=21402 DF PROTO=TCP SPT=50045 DPT=443 WINDOW=16307
Thu Oct 30 12:20:39 2014(GMT) [rv180][Kernel][KERNEL] [72859.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.144 DST=81.19.104.99 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=61687 PROTO=TCP SPT=2135 DPT=443 WINDOW=0 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:39 2014(GMT) [rv180][Kernel][KERNEL] [72862.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=212.36.254.18 LEN=133 TOS=0x00 PREC=0x00 TTL=127 ID=25836 DF PROTO=TCP SPT=58010 DPT=14750 WINDOW=259 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:20:44 2014(GMT) [rv180][Kernel][KERNEL] [72863.730000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=212.36.254.18 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=25839 DF PROTO=TCP SPT=58010 DPT=14750 WINDOW=259 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:44 2014(GMT) [rv180][Kernel][KERNEL] [72864.370000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=212.36.254.18 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=25840 DF PROTO=TCP SPT=58010 DPT=14750 WINDOW=0 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:44 2014(GMT) [rv180][Kernel][KERNEL] [72864.630000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.121 DST=193.239.68.82 LEN=52 TOS=0x00 PREC=0x00 TTL=63 ID=30996 DF PROTO=TCP SPT=49676 DPT=80 WINDOW=65535 RES=0x00 ACK FIN URGP=0 MARK=0x1
Thu Oct 30 12:20:44 2014(GMT) [rv180][Kernel][KERNEL] [72865.500000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=212.36.254.18 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=25841 DF PROTO=TCP SPT=58010 DPT=14750 WINDOW=0 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:44 2014(GMT) [rv180][Kernel][KERNEL] [72867.990000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=212.36.254.18 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=25843 DF PROTO=TCP SPT=58010 DPT=14750 WINDOW=0 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:49 2014(GMT) [rv180][Kernel][KERNEL] [72872.360000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=91.211.61.7 LEN=122 TOS=0x00 PREC=0x00 TTL=127 ID=17783 DF PROTO=TCP SPT=58027 DPT=27205 WINDOW=259 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:20:49 2014(GMT) [rv180][Kernel][KERNEL] [72872.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=91.211.61.7 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17784 DF PROTO=TCP SPT=58027 DPT=27205 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:49 2014(GMT) [rv180][Kernel][KERNEL] [72872.670000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=91.211.61.7 LEN=476 TOS=0x00 PREC=0x00 TTL=127 ID=17785 DF PROTO=TCP SPT=58027 DPT=27205 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:20:49 2014(GMT) [rv180][Kernel][KERNEL] [72872.820000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=212.36.254.18 LEN=40 TOS=0x00 PREC=0x00 TTL=127 ID=25845 DF PROTO=TCP SPT=58010 DPT=14750 WINDOW=0 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:49 2014(GMT) [rv180][Kernel][KERNEL] [72872.900000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=91.211.61.7 LEN=558 TOS=0x00 PREC=0x00 TTL=127 ID=17786 DF PROTO=TCP SPT=58027 DPT=27205 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:20:49 2014(GMT) [rv180][Kernel][KERNEL] [72873.270000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=91.211.61.7 LEN=52 TOS=0x00 PREC=0x00 TTL=127 ID=17787 DF PROTO=TCP SPT=58027 DPT=27205 WINDOW=258 RES=0x00 ACK URGP=0 MARK=0x1
Thu Oct 30 12:20:49 2014(GMT) [rv180][Kernel][KERNEL] [72873.860000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=91.211.61.7 LEN=572 TOS=0x00 PREC=0x00 TTL=127 ID=17788 DF PROTO=TCP SPT=58027 DPT=27205 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
Thu Oct 30 12:15:10 2014(GMT) [rv180][Kernel][KERNEL] [72527.220000] NO CONNTRACK FOUND [DROP]IN=bdg1 OUT=eth1 SRC=192.168.1.223 DST=2.93.178.228 LEN=646 TOS=0x00 PREC=0x00 TTL=127 ID=17648 DF PROTO=TCP SPT=57109 DPT=62292 WINDOW=258 RES=0x00 ACK PSH URGP=0 MARK=0x1
203
