Rhonda,
The setting your trying to configure is on the lan side of the router.
What your ISP is wanting you to set is on the wan side of the router.
On the lan side, this is for your private network behind the router and allows you to regulate how many addresses you will support behind it.
Your ISP is wanting you to set the subnet mask on the wan so your router will connect to their network with the specific subnet they have alloted you.
