NTP Access-group Problem
I have a setup like :
The R-1 has an NTP server and NTP peer(R-2).
On R-1 i did like: ntp sever <ntp-sever ip add>
                         ntp peer <R-2> Loopback0
                         ntp source loopback0
                         ntp update-calender
Similarly i did on R-2,but when i add a ntp access-group peer <ACL_NO> on both the routers.
Where ACL_N0 is permit host <R-2 Loopback0>
                           permit host <ntp server ip add>
With this setup the routers should sync with each other in case one's link(Let R-1 to NTP Server ) to NTP server goes down.
But the
* master (synced) value remains unchanged even when the link (R-1 to NTP Server) is down
1 REPLY
NTP peers would sync with each other when the peer is on a better Datum level (worst is 16).So if both the switches are on same datum level they will consider themselves as master.
Also use the command sh ntp status to look for the time since NTP updates came from a NTP server.
640
