password reset
please help me i cant login to my router RV042 from the browser with my local ip it tells me Wrong password
Gold
password reset
Are you certain that you are using the correct password?
Try using a different browser, sometimes some browsers are not able to send passwords properly.
As a last resort, hold the reset button for 30 seconds to reset the username and password to admin. Please note that all settings on the router will be lost and it will need to be reconfigured completely as if it was new out of the box.
- Marty
password reset
thanks for your reply, but i cant loose the info. I have VPN set up so please can you help me to login to the router to connect though console port or something
Gold
password reset
I'm sorry to inform you that there is no console access or other "back door" on the router. The only possble was to reset the password is to reset to factory defaults.
- Marty
password reset
i realy thank you for your help. I will try to remember my password otherwise i will reset it.
thanks
Atique
538
