04-11-2012 01:46 AM
Port forwarding on rv120 does not work.
I have followed the workaround instructions: so i have created a firewall access rule on incoming port 21 to an internal ip address on the same port. The router has created the forwarding port rule. But port forwarding does not work. I have tried to use a custom service but nothing!
The router is reachable from wan, I can access via DNS the configuration page and I can ping the router on wan port.
Please Help me
Many thanks
04-11-2012 02:41 AM
Instead of start with port forwarding, Create access rule where the portforwarding entry will be automatically created.
Harry
04-11-2012 03:06 AM
I have tried with custom service for port 21 but it doesn' work.
Alex
04-11-2012 03:08 AM
Use my updated reply.
Harry
04-11-2012 03:12 AM
I always start with access rule because of the firmware's bug.
04-11-2012 06:15 AM
Hello Alessandro,
From your pictures, it appears the rule has been created correctly. Here are some things to look for:
From the router, can you ping the computer you are forwarding to?
When connected locally can you reach the computer on 21?
Are you able to do a port scan from outside the network? If so what is the status of port 21?
Does the computer have a firewall that could block traffic from the internet?
If everything is correct, please feel free to call us at the support center.
04-11-2012 06:31 AM
- the router can ping the ftp server
- locally ftp server is reachable
- from outside the only port active on the router is n. 80
- the ftp server has no firewall
If I connect another router (Zyxel NBG420) the ftp server is reachable.
04-11-2012 06:47 AM
I have done a port scan with Portqry. The test of port 21 is very slow and after many seconds appers FILTERED.
04-11-2012 06:48 AM
04-11-2012 07:01 AM
Thanks for the update. Try disabling 'block framgemented packets' under Firewall > Attack Prevention. If that does not work, delete the rule and create it under the port forwarding section.
If it still does not work, I would really recommend calling us if possible.
04-11-2012 11:15 PM
Yesterday I have restored to factory default and reconfigured all. Now it works. I don't know what was wrong!
Thanks!!!!
Alex
