New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
Port Forwarding on RV120
Port forwarding on rv120 does not work.
I have followed the workaround instructions: so i have created a firewall access rule on incoming port 21 to an internal ip address on the same port. The router has created the forwarding port rule. But port forwarding does not work. I have tried to use a custom service but nothing!
The router is reachable from wan, I can access via DNS the configuration page and I can ping the router on wan port.
Please Help me
Many thanks
Everyone's tags (2)
Community Member
Re: Port Forwarding on RV120
Instead of start with port forwarding, Create access rule where the portforwarding entry will be automatically created.
Harry
Community Member
I have tried with custom service for port 21 but it doesn' work.
Alex
Community Member
Use my updated reply.
Harry
Community Member
I always start with access rule because of the firmware's bug.
Bronze
Hello Alessandro,
From your pictures, it appears the rule has been created correctly. Here are some things to look for:
From the router, can you ping the computer you are forwarding to?
When connected locally can you reach the computer on 21?
Are you able to do a port scan from outside the network? If so what is the status of port 21?
Does the computer have a firewall that could block traffic from the internet?
If everything is correct, please feel free to call us at the support center.
Community Member
- the router can ping the ftp server
- locally ftp server is reachable
- from outside the only port active on the router is n. 80
- the ftp server has no firewall
If I connect another router (Zyxel NBG420) the ftp server is reachable.
Community Member
I have done a port scan with Portqry. The test of port 21 is very slow and after many seconds appers FILTERED.
Community Member
Bronze
Thanks for the update. Try disabling 'block framgemented packets' under Firewall > Attack Prevention. If that does not work, delete the rule and create it under the port forwarding section.
If it still does not work, I would really recommend calling us if possible.
Community Member
Yesterday I have restored to factory default and reconfigured all. Now it works. I don't know what was wrong!
Thanks!!!!
Alex
818
