Port Forwarding RV325
I have an RV325 with firmware v1.2.1.14.
I am attempting to port forward 2 ports for a security dvr on my network.
With the previous router I was using, the following ports were opened:
8085 UTP
8085 TCP
9000 UTP
9000 TCP
I am trying to add a service for this in service management.
The RV325 does not allow multiple ports to be opened.
How can I do this?
I have read all of the port forwarding articles, none discuss my predicament.
All of the other routers I have used in the past allow both TCP and UDP and multiple ports per client.
Just wondering if this is possible on the RV325 or should I return this router?
Silver
Its possible.
Login to webpage > setup > forwarding, click on service managment, table window will appear. Click add to add new service. choose name, protocol and enter port range number. click on add. it will appear on the table.
do it again for the second service.
Hope thats help
Thank you for your response.
HOWEVER, there is no way to add multiple services to any one computer on my network.
This is the problem I am having.
Like I mentioned earlier,
I need these ports opened:
8085 UDP
8085 TCP
9000 UDP
9000 TCP
So you are telling me I need to setup a separate service for each one?
One service for 8085 UDP,
Another service for 8085 TCP
Another service for 9000 UDP
Another service for 9000 TCP
Ok fine. I knew that was possible (not convenient , but possible)
Then how do you apply all of these to one PC or client on the network? The router only allows one service to be selected, I have four now.
I paid double the price for this router because I wanted a quality unit, but I am having second thoughts and I will probably return it if this is not resolved.
Any help is appreciated!
Silver
ckeays123,
ckeays123,
Chick attachment below, page 35. It will help.
If post was helpful, please rate it.
HOWEVER, the pdf is generic and does not address the issues I am having.
146
