Ports to Forward
Hi just got the RV220W it will sit behind a ISP DSL router. What are all the ports I need to forward from the DSL router to the Cisco RV220W for all VPN access SSL,PPTP,IPsec
Thanks In advance Keith
1 REPLY
You'll need to forward the
You'll need to forward the following:
Ports:
443/tcp (SSL)
1723/tcp (PPTP)
500/udp (IPSec)
4500/udp (IPSec)
10000/tcp (IPSec)
Protocols:
47 (PPTP)
50 (IPSec)
51 (IPSec)
Almost all ISP routers will let you forward ports, but many can't forward protocols, so it's usually easiest to use the ISP router's "DMZ" functionality to just forward everything to the RV220's WAN address.
43
