Privilege Level Authorization Access
Can anyone tell me how to authorize show run command to privilege level less than 15?
I have tried to authorize the show run command to privilege level 3 but it is not showing the complete configuration. It is just showing the configuration size and when last configuration was changed.
Mukesh Kumar
Network Engineer
Spooster IT Services
Bronze
Expected behavior, please
Expected behavior, please refer to the following link
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a00800949d5.shtml
for more info.
regards
Moorthy
Hello MoorthyThanks for your
Hello Moorthy
Thanks for your response.
The command that you have told does not show the full running configuration. I have found some commands to see the full running configuration. Here are the following command that we have to configure on the device:
(config)# privilege exec all level 3 show running-config
To see the full running configuration we have to use the following command:
# show running-config view full
But these commands are not supported on Version 12.2(25r)SEE4.
Is there any other method to see the complete running configuration?
Mukesh Kumar
Network Engineer
Hello Moorthy,Does Parser
Hello Moorthy,
Does Parser View feature available in 12.2(25r)SEE4 IOS version?
I want to give privilege level 3 to a user and he can run the command "show run".
Mukesh Kumar
Network Engineer
Bronze
Use this below examples :
Use this below examples :(shown for some of the commands)
privilege exec level 3 traceroute
privilege exec level 3 ping
privilege exec level 3 show ip
privilege exec level 3 show startup-config
privilege exec level 3 show running-config
privilege exec level 3 show configuration
privilege exec level 3 clear counters
Hello MoorthyAfter running
Hello Moorthy
After running these commands still i am not able to see the full running configuration.
It shows the following output when i run "show running-config" command.
Output:
R1#show run
Building configuration...
Current configuration : 53 bytes
boot-start-marker
boot-end-marker
end
Is there any method to give access of "show run" command to the user of privilege level 3?
Mukesh Kumar
Network Engineer
126
