Problem establishing a IPSec VPN with SRP527W
Hi.
I've a configuration like this:
192.168.15.0/24 SRP527W <-> internet <-> ROUTER [172.16.16.1] <1:1 NAT> pfSense (racoon vpn server) [172.16.16.2] 192.168.55.0/24
I've configured a VPN connection between the SRP and pfsense but the connection doesn't get establised because phase1 timeout. according to racoon the Remote Side not responding.
Before this, I've correctly established a VPN between this SRP and another pfsense box, but with a public IP address. From the same host I've another vpn to the pfsense box (172.16.16.1) correctly working.
These the settings on the SRP:
IKE Policy:
Exchange mode: aggressive
Enabled ID: Manual
Remote ID: 172.16.16.2
Encryption: 3DES
Authentication: MD5
DH Group: Group 2
PSK: mysharedkey
DPD: disabled
IPSec Policy:
Policy Type: auto policy
Remote endpoint: IP ADDRESS
IP: 172.16.16.2
SA Lifetime: 7800
Local and remote subnet setting according to the network setup above (192.168.x.x).
How can I check what's wrong? I struggled for several hours now and haven't managed to get out yet! Any help really welcome!
1 ACCEPTED SOLUTION
Gold
Lorenzo,
Does the router at 172.16.16.1 allow all traffic to the pfsense VPN server when One-to-One NAT is enabled or do you have to create access rules? My guess is that the router is blocking the traffic.
- Marty
Gold
Lorenzo,
- Marty
(sorry I wrongly marked the reply as correct, but it's not. is it possible to undo?)
I have no control on the router at 172.16.16.1 but I've been told a 1:1 NAT has been applied.
To value that I have a working VPN configured to that host (but coming from another pfsense), so all forwards should be in place
166
