Community Member
QoS over IPsec on Small Business Router - RV220W
I am trying to configure QoS over IPsec connecetion between two RV220W routers.
-WAN QoS Profiles are not working, having configured every possible way, using both priority settings and rate limit (1mbps)
-Using Profile Binding, traffic selector using IP addresses are not working (tried using the source, destination, for the LAN and WAN IP addresses)
-Speed tests are not showing any change no matter how differently I change the options.
I have read this article (http://www.cisco.com/c/en/us/td/docs/security/asa/asa92/configuration/firewall/asa-firewall-cli/conns-qos.html) and found out that
For IPsec-encrypted packets, you can only match traffic based on the DSCP or precedence setting.
–   IPsec-over-TCP is not supported for priority traffic classification.
I am unfamiliar with DSCP and would appreciate some suggestions as how to configure QoS over IPsec between two RV220W Routers.
If you need any other info let me know.
Everyone's tags (1)
1 REPLY
Community Member
Doing more research into this
Doing more research into this I have discovered that I need to configure a DVTI to apply QoS.
Am I on the right track?
59
